Did you remember to switch the board back to UNO before uploading? The UNO uses a faster baudrate than the Duemilanove.
Did you add anything to the UNO to disable Auto-reset while you were using it as an ISP? You have to re-enable Auto-reset to upload sketches (or use a manual reset).
johnwasser:
yes I set the board to UNO
I made the UNO myself so I added a auto reset jumper and that was installed
The Arduino is not resetting when the serial port is opened.
The Arduino does not have a bootloader on it.
The Arduino has the wrong bootloader on it (i.e. not the standard one for a UNO).
The Arduino fuses are wrongly set.
The Arduino is not connected correctly to the USB interface (for example due to other hardware being connected to the serial pins).
I suspected for a long time that the bootloader or fuses could be at fault but had no way to check until 10 mins ago
also if I wanted to do the -f override what is the avrdude cmd command to load a hex
thanks
my USBASP has just arrived
I have looked at the chip and the Device signature for it is 0x1e9514 and AVRDUDE does not like it
I have another chip and that's fine with a device signature of 0x1e950f
maybe I could try reflashig the bootloader as this chip with incorrect sig was a preloaded chip I got where as the correct sig chip was a blank that I loaded
silverfox0786:
can a duemilanove have a 328 as i can swap the chips over and reflash the bootloaders
im very surprised at that as the seller assured me that i was gonna get a UNO preloaded 328
silverfox0786:
I think the Duemilanove also uses the 328P.
your right is does as i did switch them over
with that's said though i have changed to the 328P on the UNO loaded Optiboot and its working fine
