I'm trying to use an SD card to load configuration data for a robot I'm working on, but I can only read data from the SD card up to a certain point. In other words, while the data on my card may say "ABCDEFG", what I actually get is "ABCDE". I'm curious if it has to do with the Serial or SD buffer being full, or if there's an error somewhere else.
Here is the actual content of my SD card file (config.txt):
A AXIS_DISTANCE_X 11494
B START_X 5715
C START_Y 3778
D PULLEY_R 100
E STEPS_PER_ROT 800
F servoPin 18
G ledPin 17
H stepPinM1 6
I dirPinM1 7
J stepPinM2 8
K dirPinM2 9
L pauseButtonPin 19
My sketch then consumes and processes each line, associating the numbers at the end of each line with the relevant variable in the Arduino sketch. For debugging, I have my sketch directly output any data that it does not understand, which results in:
L pause
The relevant code looks something like this:
// Open the config file
configFile = SD.open("config.txt");
// Abort if file loading failed
if(!configFile) {
Serial.println("failed");
return false;
currentFile = configFile;
// Read data from config file
// Data format = {id} {variable name} {value}
while(configFile.available()) {
int id = configFile.read();
switch(id) {
// A = AXIS_DISTANCE_X
case 'A':
// Throw away variable name (17 bytes)
for(int i=0; i<17; i++)
configFile.read();
AXIS_DISTANCE_X = readLong();
configFile.read();
Serial.print(" AXIS_DISTANCE_X = ");
Serial.println(AXIS_DISTANCE_X);
// more cases
case 'K':
for(int i=0; i<10; i++)
configFile.read();
dirPinM2 = readLong();
configFile.read();
Serial.print(" dirPinM2 = ");
Serial.println(dirPinM2);
case 'L':
Serial.println("found L");
for(int i=0; i<16; i++)
configFile.read();
pauseButtonPin = readLong();
Serial.print(" pauseButtonPin = ");
Serial.println(pauseButtonPin);
default:
Serial.write(id);
It would be very funny if the word "pause" actually is triggering some sort of pausing behavior, but who knows? Any ideas?
