Hi All, I am facing a problem uploading sketches to ESP8266-12E. The problem is that only once the sketch is uploading to the ESP8266 but if I am loading any sketch again it is not happening. I have tried around 5 numbers of ESP8266-12E but I am getting the same problem. I have used NodeMCU and FTDI for programming the controller but results are same.I am tired of working on it to resolve the issue. So kindly advise how to resolve the problem and what would have been the reason for it?.
I tried with some basic codes such as 'Blink' and 'Button' from the examples other than my codes for testing but its uploading also getting failed.
The error message I am getting are mentioned below:
Arduino: 1.8.13 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new can abort), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Executable segment sizes:
IROM : 392220 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 28292 / 32768 - code in IRAM (ICACHE_RAM_ATTR, ISRs...)
DATA : 1256 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 3400 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 26048 ) - zeroed variables (global, static) in RAM/HEAP
Sketch uses 425168 bytes (40%) of program storage space. Maximum is 1044464 bytes.
Global variables use 30704 bytes (37%) of dynamic memory, leaving 51216 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.8
Serial port COM3
Connecting........_____....._____....._____....._____....._____....._____.....____Traceback (most recent call last):
File "C:\Users\SUNIL\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/SUNIL/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/SUNIL/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet content
Thanks in advance..
Sunil
