I am working on a school project, where I have to log GPS and acceleration data to an sd card at the same time, but I cannot get it to work. Logging GPS and acceleration data separately work fine.
The mpu6050 used to measure acceleration uses i2c communication, and the neo-GPS 6m uses softwareSerial.
The code doesn't even write the csv titles in the setup()
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include "SoftwareSerial.h"
#include <MPU6050_tockn.h>
#include "TinyGPS++.h"
int RXPin = 3;
int TXPin = 2;
String fileName = "data";
int count = 0;
bool file = false;
float deltaTime;
MPU6050 mpu6050(Wire);
File dataFile;
TinyGPSPlus gps;
SoftwareSerial serial_connection(RXPin, TXPin);
void setup(){
//Serial begin
serial_connection.begin(9600);
//SD card begin
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
//Checks if file already exists
while(!file){
if(SD.exists(fileName + ".csv")){
count++;
fileName = "data" + String(count);
}else{
file = true;
dataFile = SD.open((fileName + ".csv"), FILE_WRITE);
if(dataFile){
dataFile.print("time");
dataFile.print(",");
dataFile.print("x");
dataFile.print("y");
dataFile.print("z");
dataFile.print("GPS_time");
dataFile.print("Latitude");
dataFile.print("Longitude");
dataFile.print("m/s");
dataFile.print("km/h");
dataFile.print("altitude (m)");
dataFile.println("satellites");
dataFile.close();
}else{
Serial.println("error opening sd card");
//MPU6050
Wire.begin();
mpu6050.begin();
Serial.println("initialization done.");
delay(100);
deltaTime = millis();
void loop(){
while(serial_connection.available()){
gps.encode(serial_connection.read());
mpu6050.update();
if(dataFile){
dataFile.print(millis()- deltaTime);
dataFile.print(mpu6050.getAccX());
dataFile.print(mpu6050.getAccY());
dataFile.println(mpu6050.getAccZ());
dataFile.print(gps.time.value());
dataFile.print(gps.location.lat(), 6);
dataFile.print(gps.location.lng(), 6);
dataFile.print(gps.speed.mps());
dataFile.print(gps.speed.kmph());
dataFile.print(gps.altitude.meters());
dataFile.println(gps.satellites.value());
dataFile.close();
}else{
Serial.println("Does not log data!");
Serial.print(millis() - deltaTime);
Serial.print(" X: ");Serial.print(mpu6050.getAccX());
Serial.print(" Y: ");Serial.print(mpu6050.getAccY());
Serial.print(" Z: ");Serial.println(mpu6050.getAccZ());
Serial.print(",");
Serial.print(gps.time.value());
Serial.print(",");
Serial.print(gps.location.lat(), 6);
Serial.print(",");
Serial.print(gps.location.lng(), 6);
Serial.print(",");
Serial.print(gps.speed.mps());
Serial.print(",");
Serial.print(gps.speed.kmph());
Serial.print(",");
Serial.print(gps.altitude.meters());
Serial.print(",");
Serial.println(gps.satellites.value());
