Can't make a Web Server Led work after login form using HTML to a page
Hi, everybody… I’m having a hard time to make my code work…
I’ve got a code that asks for a login and password, than it shows some inputs and it works fine…
Login is satarun and password is password
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,2, 111);
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
void SendOKpage(EthernetClient &client)
// send a standard http response header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println(“Connnection: close”);
client.println();
client.println("");
client.println("");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
client.println("<meta http-equiv=“refresh” content=“5”>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print(“analog input “);
client.print(analogChannel);
client.print(” is “);
client.print(sensorReading);
client.println(”
client.println(””);
void SendAuthentificationpage(EthernetClient &client)
client.println(“HTTP/1.1 401 Authorization Required”);
client.println(“WWW-Authenticate: Basic realm=“Secure Area””);
client.println();
client.println("");
client.println(" Error");
client.println("
401 Unauthorized.
char linebuf[80];
int charcount=0;
boolean authentificated=false;
// listen for incoming clients
if (client) {
Serial.println(“new client”);
memset(linebuf,0,sizeof(linebuf));
charcount=0;
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
linebuf[charcount]=c;
if (charcount<sizeof(linebuf)-1) charcount++;
Serial.write(c);
// if you’ve gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == ‘\n’ && currentLineIsBlank) {
if (authentificated)
SendOKpage(client);
SendAuthentificationpage(client);
if (c == ‘\n’) {
// you’re starting a new line
if (strstr(linebuf,“Authorization: Basic”)>0 && strstr(linebuf,“c2F0YXJ1bjpwYXNzd29yZA==”)>0)
authentificated=true;
charcount=0;
else if (c != ‘\r’) {
// you’ve gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println(“client disonnected”);
The problem is that I can’t make it work when I mix both codes trying to turn on/off a led from the internet with a simple example of a Web Server 2 Leds simple code like the one below:
int led1 = 8;
int led2 = 9;
char c = 0;
char command[2] = “\0”;
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
if (client) {
boolean current_line_is_first = true;
boolean current_line_is_blank = true;
if (c == ‘\n’ && current_line_is_blank) {
client.println(“Refresh: 3”);
client.println();
client.println("<body background-color:#040300>");
client.println("
Welcome you!
client.println("
client.println(”
client.println(”");
client.println(“Led1 ON”);
client.println(“Led1 OFF”);
client.println("
client.println(”
"); client.println("Led2 ON"); client.println("Led2 OFF"); client.println("
if (c == ‘\n’) {
current_line_is_first = false;
current_line_is_blank = false;
if (current_line_is_first && c == ‘=’) {
for (int i = 0; i < 1; i++) {
c = client.read();
command = c;
if (!strcmp(command, “1”)) {
digitalWrite(led1, HIGH);
else if (!strcmp(command, “2”)) {
digitalWrite(led1, LOW);
if (!strcmp(command, “3”)) {
digitalWrite(led2, HIGH);
else if (!strcmp(command, “4”)) {
digitalWrite(led2, LOW);
client.stop();
client.println("");
Could anybody help me putting both codes together ?
Isyourspacekeybroken?Ifitis,youshouldgetitfixed.
Your code is about impossible to read because there is no white space.
