Hey everyone,
For a project I am making a servo controlled security camera arm. the arm and camera serve as a prop, so the camera is not real.
I have made a arm with two servo’s in it. One to move horizontally (180*) and the other to move vertical (135*), controlled with a arduino uno.
The idea is that the camera is looking down to a person sitting on a chair.
when a input is given to the arduino (for now I am doing this with a switch), the camera will quickly look away, and will begin to look around facing up. As if it was not spying on the person.
when the input from the switch is removed, the camera will slowly go back to spying on the person in the chair. so facing down.
My problem is that i can’t get the camera to move correctly. it shoots down, in between tasks, and i don’t know why
my servo’s are connected to pin 10 and 9, and the switch is connected to pin 8.
and this is the code I am using:
If you know anything that could help I would be really greatfull, thanks!
const int buttonPin = 8; // the number of the pushbutton pin
#include <Servo.h>
Servo servotop; // create servo object to control a servo
Servo servobelow; // a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
int buttonState = 0; // variable for reading the pushbutton status
pinMode(buttonPin, INPUT);
servotop.attach(9);
servobelow.attach(10);
// attaches the servotop on pin 9 and servobelow on pin 10 to the servo object
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH)
// turn servotop on (look away):
for(pos = 30; pos < 150; pos += 1) // goes from 30 degrees to 150 degrees
{ // in steps of 1 degree
servotop.write(pos); // tell servo to go to position in variable ‘pos’
delay(50); // waits 50ms for the servo to reach the position
for(pos = 150; pos < 30; pos += 1) // goes from 150 degrees to 30 degrees
// turn servobelow on (look away):
for(pos = 111; pos < 180; pos += 1) // goes from 111 degrees to 180 degrees
servobelow.write(pos); // tell servo to go to position in variable ‘pos’
// return to start position (he will never know):
else {
servotop.write(100); // tell servo to go to position in variable ‘pos’
delay(50); // waits …ms for the servo to reach the position
servobelow.write(111); // tell servo to go to position in variable ‘pos’
