Hi, I am writting my own CNC stepper-motor firmware and everything freezed on point that I am unable to move the steppers. I created simple program for flashing led which worked (pin 2-gnd: half brigthness, and 8-gnd: full brightness), so I plugged in cnc shield, but nothing happened. On init, I set ‘enable’ pin to HIGH (pin 8 / portb0), set ‘direction X’ to HIGH (pin 5 / portd5) and start toggling ‘step X’ (pin 2 / portd2) every tick. I basically wrote 2 programs, both are working fine with led, but don’t work with stepper motor shield.
This one is non-arduino:
#include <avr/interrupt.h>
#include <avr/io.h>
#include <stdint.h>
int main() {
// Timer enable
// Enable internal transistors for higher current
//DDRD = (1<<2) | (1<<5);
//DDRB = (1<<0);
PORTB = (1 << 0); //pin 8 high
PORTD = (1<<5); // X dir 1
PORTD = PORTD & ~(1 << 2); //X step 0
//uint8_t saved_state = SREG;
//cli();
OCR2A = 127;
TCCR2B = (1 << CS21); //prescaller 8
TCCR2A = (1 << WGM21); //CTC, top=ocra
TIMSK2 = (1 << OCIE2A); // global interrupts enabled
//SREG = saved_state; //reneable interrupts
sei();
//Infinite loop, just stepping
while(1) {}
__builtin_unreachable();
//Called every 64 us
char bef = 0;
ISR(TIMER2_COMPA_vect) {
PORTD = PORTD & ~(1 << 2) | ((bef = !bef) << 2);
and this one is written in arduino:
// testing a stepper motor with a Pololu A4988 driver board or equivalent
// on an Uno the onboard led will flash with each step
// this version uses delay() to manage timing
byte directionPin = 5;
byte stepPin = 2;
int pulseWidthMicros = 20; // microseconds
int mcrSteps = 250; // delay between steps
Serial.println("Starting StepperTest");
pinMode(directionPin, OUTPUT);
pinMode(stepPin, OUTPUT);
pinMode(8, OUTPUT); //enable pin
delay(3000);
digitalWrite(8, HIGH); // enable
digitalWrite(directionPin, HIGH);
int n = 0;
while(1) {
Serial.print((n++&1)?"_":"-");
digitalWrite(stepPin, HIGH);
delayMicroseconds(pulseWidthMicros); // probably not needed
digitalWrite(stepPin, LOW);
delayMicroseconds(mcrSteps);
Of course, I tested the shield with latest GRBL and it worked OK, stepper was moving. Probably I need to turn any PIN on, but I really don’t know which one. Thanks
