Hi all,
First - I am a newb so if any of this should be remedial, I apologize.
I connected a WINGONEER 5Pcs 4x4 Universial 16 Key Switch Keypad Keyboard to my Mega2560. I got a string of errors, starting with this...
avrdude: ser_open(): can't open device "/dev/cu.usbmodem14301": No such file or directory
Pins connected to 2 through 9, no issue there I suspect. This error continues after the board is powered down, the keypad disconnected. After some period of time or sequence of events the last time, the board reset and code loaded no problem. Powered down, reconnected keypad, same issue.
This had been working on a previous Mega2560, but that board got burned out.
Code doesn't seem relevant, as it does it with just:
Mac USB System Report shows:
Communication Device:
Product ID: 0x0042
Vendor ID: 0x2341
Version: 0.01
Serial Number: 85937313237351D03270
Speed: Up to 12 Mb/s
Manufacturer: Arduino (www.arduino.cc)
Location ID: 0x14400000 / 1
Current Available (mA): 500
Current Required (mA): 100
Extra Operating Current (mA): 0
Tried burning bootloader but got this error:
Arduino: 1.8.13 (Mac OS X), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Error while burning bootloader.
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/XXXXX/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/XXXXX/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14301
Using Programmer : wiring
Overriding Baud Rate : 115200
ioctl("TIOCMGET"): Inappropriate ioctl for device
avrdude: ser_send(): write error: Bad file descriptor
avrdude: stk500_send(): failed to send command to serial port
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
