I decided to make another topic because my question from my original post was answered. The OP can be found here:
Here is my code as of right now:
// Serial data logger example.
// Maximum baud rate for a 328 Arduino is 57600.
// Maximum baud rate for a Mega Arduino is 115200.
const uint32_t BAUD_RATE = 115200;
// Maximum time between sync() calls in milliseconds. If Serial is always
// active, you must provide a way to stop the program and close the file.
const uint32_t MAX_TXSYNC_TIME_MSEC = 1000;
const uint32_t MAX_RXSYNC_TIME_MSEC = 2000;
// Pin number for error blink LED.
// Set ERROR_LED_PIN to -1 for no error LED.
const int8_t ERROR_LED_PIN = 22;
const int8_t CHIP_SELECT = 53; // Set to 53 cause using with a Mega
// File names to save files on the SD card
char TxFileName[11];
char RxFileName[11];
#include <SPI.h>
#include <SdFat.h>
#include <Sd2Card.h>
#include <SerialPort.h>
#include <Wire.h>
#include <RTClib.h>
#if defined(__AVR_ATmega1280__)\
|| defined(__AVR_ATmega2560__)
// Mega, use 4096 byte RX buffer
SerialPort<0, 2048, 0> NewSerial;
SerialPort<1, 2048, 0> NewSerial1;
SerialPort<2, 2048, 0> NewSerial2;
#else // Mega
// not a Mega, use 1024 RX byte buffer
SerialPort<0, 1024, 0> NewSerial;
#endif
SdFat sd;
SdFile logfile;
RTC_DS1307 RTC;
// Error codes repeat as errno short blinks with a delay between codes.
const uint8_t ERROR_INIT = 1; // SD init error
const uint8_t ERROR_OPEN = 2; // file open error
const uint8_t ERROR_SERIAL = 3; // serial error
const uint8_t ERROR_TXWRITE = 4; // SD write or sync error
const uint8_t ERROR_RTC = 5; // DTC did not begin
const uint8_t ERROR_RXOPEN = 6; // Rx File open error
const uint8_t ERROR_RXWRITE = 7; // Can't write or sync the RX file
const uint8_t ERROR_LOOP_OPEN = 8; // Cant open file in the loop
void errorBlink(uint8_t errno) {
uint8_t i;
while (ERROR_LED_PIN < 0);
while (1) {
for (i = 0; i < errno; i++) {
digitalWrite(ERROR_LED_PIN, HIGH);
delay(200);
digitalWrite(ERROR_LED_PIN, LOW);
delay(200);
NewSerial.println(errno);
delay(1600);
pinMode(ERROR_LED_PIN, OUTPUT);
pinMode(CHIP_SELECT, OUTPUT);
NewSerial.begin(BAUD_RATE);
NewSerial1.begin(BAUD_RATE);
NewSerial2.begin(BAUD_RATE);
if (!sd.begin(CHIP_SELECT)) {
errorBlink(ERROR_INIT);
// Create new TX file on SD card
char TxFile[] = "GR_TX00.csv";
for (uint8_t i = 0; i <100; i++){
TxFile[5] = i/10 + '0';
TxFile[6] = i%10 + '0';
if (! sd.exists(TxFile)){
// Only open new file if it doesn't exist
if (!logfile.open(TxFile, O_WRITE | O_CREAT | O_AT_END)){
errorBlink(ERROR_OPEN);}
strncpy(TxFileName,TxFile,sizeof(TxFile));
break; //leave loop
if (logfile.fileSize() == 0) {
// Make sure first cluster is allocated.
logfile.write((uint8_t)0);
logfile.rewind();
logfile.sync();
// Create new RX file on SD card
// Close the TX file first
logfile.close();
char RxFile[] = "GR_RX00.csv";
RxFile[5] = i/10 + '0';
RxFile[6] = i%10 + '0';
if (! sd.exists(RxFile)){
if (!logfile.open(RxFile, O_WRITE | O_CREAT | O_AT_END)){
errorBlink(ERROR_RXOPEN);}
break; //leave loop
logfile.rewind();
logfile.sync();
// Close the Rx file
logfile.close();
// Connect to the RTC
Wire.begin();
if (!RTC.begin()){
// Save to Tx file
logfile.open(TxFile, O_WRITE);
logfile.println("RTC Failed");
logfile.close();
errorBlink(ERROR_RTC);
// Save to Rx file
logfile.open(RxFile, O_WRITE);
logfile.close();
// Get RTC time at start up
DateTime now;
// Fetch the current time
now = RTC.now();
// Log the time
//logfile.print(now.secondstime()); // seconds since 2000
//logfile.print(",");
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
logfile.println("");
logfile.close();
// Other File
logfile.print("/");
logfile.print("/");
logfile.print(" ");
logfile.print(":");
logfile.print(":");
logfile.close();
// DEBUGGING: Print out to the serial port to see what is going the time is.
NewSerial.print(now.year(), DEC);
NewSerial.print("/");
NewSerial.print(now.month(), DEC);
NewSerial.print(now.day(), DEC);
NewSerial.print(" ");
NewSerial.print(now.hour(), DEC);
NewSerial.print(":");
NewSerial.print(now.minute(), DEC);
NewSerial.print(now.second(), DEC);
NewSerial.println("");
// Time of last sync call.
uint32_t txSyncTime = 0;
uint32_t rxSyncTime = 0;
uint8_t buf[32];
int h = 0;
DateTime now;
uint8_t n=0;
uint8_t m=0;
// Get the Garmin TX traffic
if (NewSerial1.getRxError()) {
errorBlink(ERROR_SERIAL);
n = NewSerial1.read(buf, sizeof(buf));
if (n > 0) { // If there is something in the buffer
// Need to open the Ts file to write out the data
if (!logfile.open(TxFileName, O_WRITE)){
NewSerial.println(TxFileName);
errorBlink(ERROR_LOOP_OPEN);}
// Attempt to log the correct time stamp to file
now = RTC.now();
logfile.timestamp(T_WRITE, now.year(), now.month(), now.day(), now.hour(), now.minute(), now.second());
// Commented this out 3/13/14 to try to get the HEX values saved to the file.
//if (logfile.write(buf, n) != n) {
//errorBlink(ERROR_WRITE);
for (int i=0; i<sizeof(buf); i++){
if (buf[i]<0x10) {logfile.print("0");
logfile.print(buf[i],HEX);
logfile.print(" ");
// Get the current micros time
logfile.print(",");
logfile.println(micros());
// Don't sync if active.
return;
if ((millis() - txSyncTime) < MAX_TXSYNC_TIME_MSEC) return;
//if (!logfile.sync()) {
////NewSerial.println(TxFileName);
//NewSerial.println("can't sync to the Tx file");
//errorBlink(ERROR_TXWRITE);
txSyncTime = millis();
logfile.close();
// Log the RX side *****************************************************************
// Get the Garmin RX traffic
if (NewSerial2.getRxError()) {
m = NewSerial2.read(buf, sizeof(buf));
if (m > 0) { // If there is something in the buffer
logfile.open(RxFileName, O_WRITE);
now = RTC.now();
logfile.print(" ");
logfile.print(",");
return;
if ((millis() - rxSyncTime) < MAX_RXSYNC_TIME_MSEC) return;
//NewSerial.println("can't sync to the Rx file");
//errorBlink(ERROR_RXWRITE);
rxSyncTime = millis();
logfile.close();
h = h++;
NewSerial.print("Times through the loop: ");
NewSerial.println(h);
I keep getting an error at:
I have checked the name of TxFileName with the print statement and it shows me the file that it should GR_TXxx.csv. What would cause this error. All the examples I have looked at access the files like this. Why won’t this work?
