Hi all,
I’ve been stuck on a problem for many hours now, and I could really use some insight into what is going wrong!
I am simply trying to log temperature and humidity data from a SHT15 sensor, onto a microSD card. I am using the microSD adapter from the pjrc shop and I have double checked that the wiring is correct to the Teensy.
I’ve narrowed down the problem to: The sensor is doing something that is causing the SD card to be unable to open the file I am trying to write in. After the sensor does it’s thing, myFile = SD.open(“text.txt”, FILE_WRITE), turns out to be false and I’m not sure why that is. The SD card logs fine with all my other sensors. My code is below:
#include <SHT1X.h>
#include <SPI.h>
#include <SD.h>
File myFile;
//variables for storing values
float tempC = 0;
float tempF = 0;
float humidity = 0;
String dataStr = "";
//Create an instance of the SHT1X sensor
SHT1x sht15(A1, 13);//Data, SCK
Serial.begin(9600); // Open serial connection to report values to host
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(10)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
myFile = SD.open("test.txt", FILE_WRITE);
Serial.print("myFile1 = ");
Serial.println(myFile);
readSensor();
printOut();
dataStr += tempF;
dataStr += " ";
dataStr += tempC;
dataStr += " ";
dataStr += humidity;
dataStr += " ";
// Serial.println(dataStr);
Serial.print("myFile2 = ");
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.println(dataStr);
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
void readSensor()
// Read values from the sensor
tempC = sht15.readTemperatureC();
tempF = sht15.readTemperatureF();
humidity = sht15.readHumidity();
void printOut()
Serial.print(" Temp = ");
Serial.print(tempF);
Serial.print("F, ");
Serial.print(tempC);
Serial.println("C");
Serial.print(" Humidity = ");
Serial.print(humidity);
Serial.println("%");
Thank you for your help in advance!
-AG
