Can't overwrite on LCD 16x2 display (TINKERCAD)
// include the library code:
#include <LiquidCrystal.h>
int sensorValue = 0;
int initalVal = sensorValue;
byte arrow[9] = {
  B00000,
  B00000,
  B00100,
  B01000,
  B11111,
  B01000,
  B00100,
  B00000,
  B00000
byte clear[9] = {
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.createChar(0, arrow); // Create a custom character
  lcd.createChar(1, clear); // Create a custom character
  // Print a message to the LCD.
  lcd.clear();
  pinMode(10, INPUT);
  // read the input on analog pin 0:
  sensorValue = analogRead(A0);
  // map 3.3V to 5V
  sensorValue = map(sensorValue, 0, 1024, 0, 16);
  // conditional clear screen
  // set the cursor to column 0, line 0:
  lcd.setCursor(0, 0);
  lcd.print("I:");
  lcd.setCursor(0, 1);
  lcd.print("D:");
  // print out the value at Serial Monitor:
  if (digitalRead(10) == LOW) {
    lcd.setCursor(2, 0);
    lcd.print(sensorValue);
    lcd.setCursor(8, 0);
    lcd.write(byte(0));
      if (digitalRead(10) == HIGH) {
    lcd.write(byte(1));
    Serial.println(sensorValue);
     lcd.setCursor(2, 1);
         lcd.setCursor(8, 1);
    lcd.write(byte(0));
    lcd.write(byte(1));
void serialEvent() {
  if(Serial.available()) {
    char letter = Serial.read();
    Serial.print(letter);
    // print out the value at LCD Display:
      lcd.print(letter);
    Serial.print("UNO received: '");
    Serial.println("'");
  lcd.clear();
Hi, I have stumbled upon this problem. I'm trying to switch between the rows on the LCD display. Also with this switching, I'm trying to delete the "arrow" that was on the previous row, but this only seems to happen sometimes. You can simulate my project with the help of (TINKERCAD), here is the link to that simulation with this exact same code.
Is there any way I could do this in an easy way? Hopefully, I also want to delete the numbers on the previous row. But for now, I need help understanding how to do this.
Try you code in the Wokwi simulator
The easiest way to remove a char is just print the space char. The font is a fixed size so it will erase the position. No need for a special char.
Also, you don't need that serialEvent() function. Just put that code in loop().
What do you mean with print the space char?
Yes, I forgot to remove it when uploading the code. I've already removed it.
    lcd.print(' ');
