Hi all,
I want to be able to get a weather forecast when I'm having my holidays on board of my caravan. GPS reception works fine and also connection with openweathermap is OK. I'm using a NodeMCU 1.2 ESP-12. Typical GPS output is e.g. lat 52.302945 and lon 4.968453 (Amsterdam). Typical input needed for the openweathermap API looks the same, but when I parse the coordinates into the weatheronline API, the output on the serial monitor is nan and null. I have tried to convert the GPS output to several formats (double, float, char, string) but up to now nothing helped. Any suggestions how to solve this?
My code:
Sketch aimed at parsing GPS data from NMEA sentence
into openweather API for 8-day's weather forecast
part of sketch concerning GPS from:
https://lastminuteengineers.com/neo6m-gps-arduino-tutorial/
part of sketch concerning weather forecast from:
https://openweathermap.org/api/one-call-3#current
GPS output in displayInfo() section, rules 1110 & 111 (typically 52.303012 & 4.968256),
for use in loop, line 65, where manual input of the coordinates works fine, but copy & paste of GPS output does not
NodeMCU 1.0 (ESP-12E) on Com3
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
#include <Arduino_JSON.h>
#include <ESP32Time.h>
TinyGPSPlus gps;
SoftwareSerial gpsSerial(4, 5);
ESP32Time rtc1(-3600); // offset GMT-1
const char* ssid = "***";
const char* password = "***";
String openWeatherMapApiKey = "***";
unsigned long lastTime = 600000; //om een beginronde te starten, daarna elke 600000 milliseconden
unsigned long timerDelay = 600000; //10 minuten 600000
String jsonBuffer;
String description[8];
JSONVar datum;
JSONVar temperatuur;
gpsSerial.begin(9600);
WiFi.begin(ssid, password);
while (gpsSerial.available() > 0)
if (gps.encode(gpsSerial.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10) {
Serial.println("No GPS detected");
while (true)
If((millis() - lastTime) > timerDelay) {
if (WiFi.status() == WL_CONNECTED) {
String serverPath = "http://api.openweathermap.org/data/3.0/onecall?lat=latitude&lon=longitude&exclude=current,minutely,hourly&lang=NL&appid=***";
jsonBuffer = httpGETRequest(serverPath.c_str());
JSONVar myObject = JSON.parse(jsonBuffer);
if (JSON.typeof(myObject) == "undefined") {
return;
for (int i = 0; i <= 7; i++) {
datum = myObject["daily"][i]["dt"];
rtc1.setTime(datum);
Serial.print(rtc1.getTime("%a %d "));
temperatuur = myObject["daily"][i]["temp"]["day"];
Serial.print(double(temperatuur) - 272.15, 1);
Serial.print(" ");
Serial.println(myObject["daily"][i]["weather"][0]["description"]);
lastTime = millis();
String httpGETRequest(const char* serverName) {
WiFiClient client;
HTTPClient http;
http.begin(client, serverName);
int httpResponseCode = http.GET();
String payload = "{}";
if (httpResponseCode > 0) {
Serial.print("HTTP Response code: ");
Serial.println(httpResponseCode);
payload = http.getString();
Serial.print("Error code: ");
http.end();
return payload;
void displayInfo() {
if (gps.location.isValid()) {
latitude = Serial.println(gps.location.lat(), 6); // latitude
longitude = Serial.println(gps.location.lng(), 6); // longitude
Serial.println("Location: Not Available");
type or paste code here
