Ok so this is very confusing for me.
I have a setup where a Raspi 0 W is sending an Arduino Uno a series (27 to be exact) bytes every second via I2C.
My setup works perfectly hardware-wise as you will see in the following example.
...i get this nonsense from the serial monitor. (I of course was expecting it to print more often but it prints total nonesense)
000000000000000000000000000260
(there were a lot more line breaks between those numbers)
Does anybody have an Idea why this might not work?
The Arduino Uno has a 5V I2C bus and the Raspberry Pi has a 3.3V I2C bus. That does not match. You should use a level converter.
You need a 'flag'. A 'bool' variable that is set in the onReceive handler and then the code in the loop() checks that flag if there is new data and reset that flag.
Variables that are written in a interrupt routine and are also used in the loop() should be made 'volatile'.
When an array has 27 elements, then it is dataArray[0] up to dataArray[26] (inclusive).
A for-loop for that array is this:
for( int i=0; i<27; i++)
You use data from outside the array when you have "i <= 27".
Do you always get 27 bytes ? Not integers ? Then I suggest to use bytes.
volatile bool newData = false;
volatile byte dataArray[27];
void receiveEvent( int howMany)
if( howMany == 27) // it must be 27 bytes
Wire.readBytes( dataArray, 27);
newData = true;
if( newData)
for( int i; i<27; i++)
Serial.print( dataArray[i]);
newData = false; // reset the flag
It depends on the data if you want to use the flag to block new data until the previous data has been processed.
This is possible, but most of the time not needed:
// it must be 27 bytes and sketch must not be busy with the previous data
if( howMany == 27 and !newData)
newData = true;
If timing is important and the data must stay together at all times, then it is possible to make a copy of the data in the loop(). This is almost never done, but it might be needed.
So i managed to overcome the problem of not being able to write to a global array.
But know i have a different problem that being that the arduino or at least the serial monitor only outputs the values it Recieved after its been reset and bytes where available on the I2C.
In programming terms a 'flag' is just a variable used to signal something. You can compare it to raising and lowering a physical flag. It allows parts of the program to influence other parts. In Koepel's example it would be the 'newData' variable.
Start with the simple short example in my reply #2.
The two things after that are extras and might be needed, but first you have to make it work.
The memcpy() has this format: memcpy( pointer to destination, pointer to source, amount of bytes) http://www.cplusplus.com/reference/cstring/memcpy/.
Every time you see a 'memcpy', say out loud: "Destination, Source".
I'm sorry :-[ there are two bugs and it was not a complete example.
The setup() function and include <Wire.h> have to be added.
The readBytes should be: Wire.readBytes( (byte *) dataArray, 27);
The for-loop should be: for( int i**=0**; i<27; i++)
Then I assume that the Raspberry Pi is not sending 27 bytes.
You could fill the first of the array with the 'howMany' and set the flag. On the serial monitor, look only at the first number and ignore the rest:
// temporary test
dataArray[0] = howMany; // get the number of received bytes
newData = true;
If you want my opinion, you should not use I2C between an Arduino and Raspberry Pi in the first place. Have a look at what I wrote two weeks ago: How to make a reliable I2C bus.
