Can't print full data from Bluetooth!
hi.
I have programed with HM-10 Bluetooth BLE 4.0
Via AT command and find beacon information.
I want to program printing return values of "AT+DISI?" in real time.
this is my code.
  if (cnt == 0) {
    bluetooth.print("AT+DISI?");
  delay(50);
  cnt++;
  Serial.print(char(bluetooth.read()));
  if (cnt == 100) {
    Serial.println("*"); //line end
    cnt = 0; //clear cnt
normally, "AT+DISI?"s answers are "OK+DISISOK+DISC:4C000215:E2C56DB5DFFB48D2B060D0F5A71096E0:00000001C5:20C38FC2C26F:-052OK+DISCE"
But this code checked in Serial monitor,
printed :
"OK+DISISOK+DISC:4C000215:E2C56DB5DFFB48D2B060D0F5A71096E0:00000001C5:20COK+DISCE
lost end of some characters red colored!
their common ground, printed count of charaters are almost 70~71.
I dont know why this happend.
i hope to someone help this problem.
Thanks for patience to read my short english.
Please post all your code.
Also, post it inside code tags so it looks like this:
...code here
#include <SoftwareSerial.h>
SoftwareSerial bluetooth(8, 9);
int cnt=0;
void setup(){
  bluetooth.begin(9600);
  if (cnt == 0) {
    delay(2000);
  delay(30);
  cnt++;
  if (cnt == 100) {
    Serial.println("*"); //end line
here is full code thank you!
But, based on the code you have posted, it should probably look more like this (untested):
byte started = 0;
const char endTag[] = "DISCE";
  if (started == 0)
    started = 1;
  if (bluetooth.available())
      char charIn = bluetooth.read();
      Serial.print(charIn));
      // look for the endTag while we are processing
      if (charIn = endTag[index])
          index++;
          // it didn't match. Start the search for the end tag again.
          index = 0;
      // have we found the endTag?
      if (index == 5)
         started = 0;
         index = 0;
hongym:
So yeah, you need to use bluetooth.available(), and not use delay(). See my previous post.
this is my result.
OK+DI*
K�OK+*
K-�OK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
#miOK*
int cnt = 0;
int started = 0;
int index = 0;
  if (started == 0)
    started = 1;
    Serial.print(charIn);
      index++;
      index = 0;
    if (index == 5)
      started = 0;
      index = 0;
i cant figure out this result :frowning:
woops. Sorry.
Change to this:
    if (charIn == endTag[index])
it works! thank you!!
hongym:
Cool. Hopefully you understand why it works.
I just realised, this:
should be changed to this:
  if (started == 1 && bluetooth.available())
