Some days ago I bought a Arduino Leonardo board. I tried to get it running under Ubuntu (version 14.04 64bit), but so far I did not succeed.
I tried out several USB ports (both USB2, USB2 with additional HUB and USB3), used different USB cables but everything I tried ended up in the error log shown below.
I see the LED blinking (Pin 13), so I assume a boot loader is running. Monitoring "/dev/ttyACM1" gives me several "TEST OK"s, so I think the connection to the Leonardo board is established.
Is there someone outside who can give me a hint how I can debug further?
Sketch uses 4,252 bytes (14%) of program storage space. Maximum is 28,672 bytes.
Global variables use 151 bytes (5%) of dynamic memory, leaving 2,409 bytes for local variables. Maximum is 2,560 bytes.
Forcing reset using 1200bps open/close on port /dev/ttyACM1
PORTS {/dev/ttyACM1, /dev/ttyS0, } / {/dev/ttyACM1, /dev/ttyS0, } => {}
Uploading using selected port: /dev/ttyACM1
/usr/arduino-1.7.8-linux64/hardware/tools/avr/bin/avrdude -C/usr/arduino-1.7.8-linux64/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -P/dev/ttyACM1 -b57600 -D -Uflash:w:/tmp/build7364879576418150895.tmp/sketch_dec08a.cpp.hex:i
avrdude: Version 6.0.1, compiled on Jan 15 2015 at 13:12:29
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/usr/arduino-1.7.8-linux64/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/root/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM1
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "TEST OK"; type =
Software Version = T.E; Hardware Version = S.T
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
