can't program arduino pro mini
I am building a soldering station to drive a weller rt tip. I did not design it. It is controlled by an arduino pro mini. The soldering station is found here: Soldering Station | DebuggingLab. I have an ftdi adapter from adafruit. I jumped the power switch header and tried to program it. At first it said i was missing adafruit_gfx.h and i found it an added itr to the library i was trying to program the pro mini with. The pro mini is soldered to my circuit board but i do not have the 1.8 inch tft screen attached yet. I am still waiting for it to come in the mail. I also have not connected my potentiometer. I have also set it to pro mini in the software and i have set it to set rts on close. Here is the error i keep getting:
Arduino: 1.6.8 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\jrs\Documents\Arduino\libraries" -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10608 -build-path "C:\Users\jrs\AppData\Local\Temp\buildc674c2606f182ca468c23ea3350db106.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\jrs\Documents\SolderStation\SolderStation.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\jrs\Documents\Arduino\libraries" -fqbn=arduino:avr:pro:cpu=16MHzatmega328 -ide-version=10608 -build-path "C:\Users\jrs\AppData\Local\Temp\buildc674c2606f182ca468c23ea3350db106.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\jrs\Documents\SolderStation\SolderStation.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\jrs\AppData\Local\Temp\buildc674c2606f182ca468c23ea3350db106.tmp\sketch\SolderStation.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "C:\Users\jrs\AppData\Local\Temp\buildc674c2606f182ca468c23ea3350db106.tmp\sketch\SolderStation.ino.cpp" -o "C:\Users\jrs\AppData\Local\Temp\buildc674c2606f182ca468c23ea3350db106.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\jrs\Documents\SolderStation\SolderStation.ino:9:54: fatal error: Adafruit_GFX.h: No such file or directory
 #include <Adafruit_GFX.h>    // Core graphics library
compilation terminated.
exit status 1
Error compiling for board Arduino Pro or Pro Mini.
Hello,
Read this: http://www.arduino.cc/en/Guide/Libraries
I prefer to install libraries manually.
guix: Hello,
i did that and all ofmy files are in a library an i tried programming the arduino with that library and i got an error:
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\jrs\Documents\Arduino\libraries\SolderStation" "C:\Users\jrs\AppData\Local\Temp\buildc674c2606f182ca468c23ea3350db106.tmp\sketch\SolderStation.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_PRO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\eightanaloginputs" "-IC:\Users\jrs\Documents\Arduino\libraries\SolderStation" "C:\Users\jrs\AppData\Local\Temp\buildc674c2606f182ca468c23ea3350db106.tmp\sketch\SolderStation.ino.cpp" -o "C:\Users\jrs\AppData\Local\Temp\buildc674c2606f182ca468c23ea3350db106.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\jrs\Documents\SolderStation\SolderStation.ino:1:0:
C:\Users\jrs\Documents\Arduino\libraries\SolderStation/Adafruit_GFX.h:11:21: fatal error: gfxfont.h: No such file or directory
 #include "gfxfont.h"
Using library SolderStation in folder: C:\Users\jrs\Documents\Arduino\libraries\SolderStation (legacy)
exit status 1
Download and install library from here: https://github.com/adafruit/Adafruit-GFX-Library
Don't forget to remove "-master" from library folder name. Do not put the library files in another folder like you did.
i installed the libraries but now i am getting this error:
iron.h:9: error: variable 'iron' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 uint8_t iron[] PROGMEM={
stationLOGO.h:9: error: variable 'stationLOGO1' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 uint8_t stationLOGO1[] PROGMEM={
stationLOGO.h:60: error: variable 'stationLOGO2' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 uint8_t stationLOGO2[] PROGMEM={
stationLOGO.h:110: error: variable 'stationLOGO3' must be const in order to be put into read-only section by means of '__attribute__((progmem))'
 uint8_t stationLOGO3[] PROGMEM={
C:\Users\jrs\AppData\Local\Temp\arduino_modified_sketch_220997\SolderStation.ino: In function 'void setup()':
SolderStation:73: error: 'setPwmFrequency' was not declared in this scope
  setPwmFrequency(PWMpin, PWM_DIV);
SolderStation:90: error: 'Color565' was not declared in this scope
  tft.drawBitmap(3,3,stationLOGO2,124,47,Color565(254,147,52));
C:\Users\jrs\AppData\Local\Temp\arduino_modified_sketch_220997\SolderStation.ino: In function 'void loop()':
SolderStation:163: error: 'getTemperature' was not declared in this scope
  int actual_temperature = getTemperature();
SolderStation:212: error: 'writeHEATING' was not declared in this scope
  writeHEATING(soll_temp, actual_temperature, pwm);
C:\Users\jrs\AppData\Local\Temp\arduino_modified_sketch_220997\SolderStation.ino: In function 'void writeHEATING(int, int, int)':
SolderStation:273: error: 'Color565' was not declared in this scope
   tft.setTextColor(Color565(tempDIV, 255-tempDIV, 0));
exit status 1
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                 from C:\Users\jrs\AppData\Local\Temp\build21e3db0e048e65828116fade866be0d2.tmp\sketch\SolderStation.ino.cpp:1:
C:\Users\jrs\AppData\Local\Temp\arduino_modified_sketch_20526\SolderStation.ino: In function 'void setup()':
C:\Users\jrs\AppData\Local\Temp\arduino_modified_sketch_20526\SolderStation.ino: In function 'void loop()':
C:\Users\jrs\AppData\Local\Temp\arduino_modified_sketch_20526\SolderStation.ino: In function 'void writeHEATING(int, int, int)':
U
i found a solution to that error, but i have a new error: 'Color565' was not declared in this scope
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Thanks… Tom… :slight_smile:
I did not write it. I downloaded it off of github
// Soldering Station
// Matthias Wagner
// www.k-pank.de/so
// Get.A.Soldering.Station@gmail.com
#include <Adafruit_QDTech.h> // Hardware-specific library
#include <SPI.h>
#include "iron.h"
#include "stationLOGO.h"
#define VERSION "1.5"		//Version der Steuerung
#define INTRO
#define sclk 	13		// Don't change
#define mosi 	11		// Don't change
#define cs_tft	10		//
//V1.5
#define dc   	9		// 8
#define rst  	12		// 9
//V1.4
#define dc   	8
#define rst  	9
#define STANDBYin A4
#define POTI   	A5
#define TEMPin 	A7
#define PWMpin 	3
#define BLpin		5
#define CNTRL_GAIN 10
#define DELAY_MAIN_LOOP 	10
#define DELAY_MEASURE 		50
//#define ADC_TO_TEMP_GAIN 	0.415
#define ADC_TO_TEMP_GAIN 	0.53 //Mit original Weller Station verglichen
#define ADC_TO_TEMP_OFFSET 25.0
#define STANDBY_TEMP			175
#define OVER_SHOT 			2
#define MAX_PWM_LOW			180
#define MAX_PWM_HI			210		//254
#define MAX_POTI				400		//400Grad C
#define PWM_DIV 1024						//default: 64   31250/64 = 2ms
Adafruit_QDTech tft = Adafruit_QDTech(cs_tft, dc, rst);  // Invoke custom library
int pwm = 0; //pwm Out Val 0.. 255
int soll_temp = 300;
boolean standby_act = false;
void setup(void) {
	pinMode(BLpin, OUTPUT);
	digitalWrite(BLpin, LOW);
	pinMode(STANDBYin, INPUT_PULLUP);
	pinMode(PWMpin, OUTPUT);
	digitalWrite(PWMpin, LOW);
	tft.init();
	SPI.setClockDivider(SPI_CLOCK_DIV4);  // 4MHz
	tft.setRotation(0);	// 0 - Portrait, 1 - Lanscape
	tft.fillScreen(QDTech_BLACK);
	tft.setTextWrap(true);
	//Print station Logo
	tft.drawBitmap(2,1,stationLOGO1,124,47,QDTech_GREY);
	tft.drawBitmap(3,3,stationLOGO1,124,47,QDTech_YELLOW);
	tft.drawBitmap(3,3,stationLOGO3,124,47,Color565(255,78,0));
	//BAcklight on
	digitalWrite(BLpin, HIGH);
#if defined(INTRO)
	//Print Iron
	tft.drawBitmap(15,50,iron,100,106,QDTech_GREY);
	tft.drawBitmap(17,52,iron,100,106,QDTech_YELLOW);
	tft.setTextSize(2);
	tft.setTextColor(QDTech_GREY);
	tft.setCursor(70,130);
	tft.print(VERSION);
	tft.setTextSize(2);
	tft.setTextColor(QDTech_YELLOW);
	tft.setCursor(72,132);
	tft.print(VERSION);
	tft.setTextSize(1);
	tft.setCursor(103,0);
	tft.print("v");
	tft.print(VERSION);
	tft.setCursor(104,1);
	tft.print("v");
	tft.print(VERSION);
	delay(2500);
#endif
	tft.fillRect(0,47,128,125,QDTech_BLACK);
	tft.setTextColor(QDTech_WHITE);
	tft.setTextSize(1);
	tft.setCursor(1,84);
	tft.print("ist");
	tft.setTextSize(2);
	tft.setCursor(117,47);
	tft.print("o");
	tft.setTextSize(1);
	tft.setCursor(1,129);
	tft.print("soll");
	tft.setTextSize(2);
	tft.setCursor(117,92);
	tft.print("o");
	tft.setCursor(80,144);
	tft.print("   %");
	tft.setTextSize(1);
	tft.setCursor(1,151);		//60
	tft.print("pwm");
	tft.setTextSize(2);
	soll_temp = map(analogRead(POTI), 0, 1024, 0, MAX_POTI);
	//TODO: Put in Funktion
	tft.setCursor(2,55);
	if (digitalRead(STANDBYin) == true)
		tft.setTextColor(QDTech_BLACK);
	tft.print("SB");
	int soll_temp_tmp = soll_temp;
	if (digitalRead(STANDBYin) == false)
		standby_act = true;
	if (standby_act && (soll_temp >= STANDBY_TEMP ))
		soll_temp_tmp = STANDBY_TEMP;
	int diff = (soll_temp_tmp + OVER_SHOT)- actual_temperature;
	pwm = diff*CNTRL_GAIN;
	int MAX_PWM;
	//Set max heating Power
	MAX_PWM = actual_temperature <= STANDBY_TEMP ? MAX_PWM_LOW : MAX_PWM_HI;
	//8 Bit Range
	pwm = pwm > MAX_PWM ? pwm = MAX_PWM : pwm < 0 ? pwm = 0 : pwm;
	//NOTfall sicherheit / Spitze nicht eingesteckt
	if (actual_temperature > 550){
		pwm = 0;
		actual_temperature = 0;
	analogWrite(PWMpin, pwm);
	//digitalWrite(PWMpin, LOW);
	delay(DELAY_MAIN_LOOP);		//wait for some time
int getTemperature()
  analogWrite(PWMpin, 0);		//switch off heater
  delay(DELAY_MEASURE);			//wait for some time (to get low pass filter in steady state)
  int adcValue = analogRead(TEMPin); // read the input on analog pin 7:
  Serial.print("ADC Value ");
  Serial.print(adcValue);
  analogWrite(PWMpin, pwm);	//switch heater back to last value
  return round(((float) adcValue)*ADC_TO_TEMP_GAIN+ADC_TO_TEMP_OFFSET); //apply linear conversion to actual temperature
void writeHEATING(int tempSOLL, int tempVAL, int pwmVAL){
	static int d_tempSOLL = 2;		//Tiefpass für Anzeige (Poti zittern)
	static int tempSOLL_OLD = 	10;
	static int tempVAL_OLD	= 	10;
	static int pwmVAL_OLD	= 	10;
	//TFT Anzeige
	pwmVAL = map(pwmVAL, 0, 254, 0, 100);
	tft.setTextSize(5);
	if (tempVAL_OLD != tempVAL){
		tft.setCursor(30,57);
		//tft.print(tempSOLL_OLD);
		//erste Stelle unterschiedlich
		if ((tempVAL_OLD/100) != (tempVAL/100)){
			tft.print(tempVAL_OLD/100);
			tft.print(" ");
		if ( ((tempVAL_OLD/10)%10) != ((tempVAL/10)%10) )
			tft.print((tempVAL_OLD/10)%10 );
			tft.print(" ");
		if ( (tempVAL_OLD%10) != (tempVAL%10) )
			tft.print(tempVAL_OLD%10 );
		if (tempVAL < 100)
			tft.print(" ");
		if (tempVAL <10)
			tft.print(" ");
		int tempDIV = round(float(tempSOLL - tempVAL)*8.5);
		tempDIV = tempDIV > 254 ? tempDIV = 254 : tempDIV < 0 ? tempDIV = 0 : tempDIV;
		if (standby_act)
			tft.setTextColor(QDTech_CYAN);
		tft.print(tempVAL);
		tempVAL_OLD = tempVAL;
	//if (tempSOLL_OLD != tempSOLL){
	if ((tempSOLL_OLD+d_tempSOLL < tempSOLL) || (tempSOLL_OLD-d_tempSOLL > tempSOLL)){
		tft.setCursor(30,102);
		if ((tempSOLL_OLD/100) != (tempSOLL/100)){
			tft.print(tempSOLL_OLD/100);
			tft.print(" ");
		if ( ((tempSOLL_OLD/10)%10) != ((tempSOLL/10)%10) )
			tft.print((tempSOLL_OLD/10)%10 );
			tft.print(" ");
		if ( (tempSOLL_OLD%10) != (tempSOLL%10) )
			tft.print(tempSOLL_OLD%10 );
		//Neuen Wert in Weiß schreiben
		if (tempSOLL < 100)
			tft.print(" ");
		if (tempSOLL <10)
			tft.print(" ");
		tft.print(tempSOLL);
		tempSOLL_OLD = tempSOLL;
	tft.setTextSize(2);
	if (pwmVAL_OLD != pwmVAL){
		//erste stelle Unterscheidlich
		if ((pwmVAL_OLD/100) != (pwmVAL/100)){
			tft.print(pwmVAL_OLD/100);
			tft.print(" ");
		if ( ((pwmVAL_OLD/10)%10) != ((pwmVAL/10)%10) )
			tft.print((pwmVAL_OLD/10)%10 );
			tft.print(" ");
		if ( (pwmVAL_OLD%10) != (pwmVAL%10) )
			tft.print(pwmVAL_OLD%10 );
		if (pwmVAL < 100)
			tft.print(" ");
		if (pwmVAL <10)
			tft.print(" ");
		tft.print(pwmVAL);
		pwmVAL_OLD = pwmVAL;
uint16_t Color565(uint8_t r, uint8_t g, uint8_t b) {
  return ((r & 0xF8) << 8) | ((g & 0xFC) << 3) | (b >> 3);
void setPwmFrequency(int pin, int divisor) {
  byte mode;
  if(pin == 5 || pin == 6 || pin == 9 || pin == 10) {
    switch(divisor) {
      case 1: mode = 0x01; break;
      case 8: mode = 0x02; break;
      case 64: mode = 0x03; break;
      case 256: mode = 0x04; break;
      case 1024: mode = 0x05; break;
      default: return;
    if(pin == 5 || pin == 6) {
      TCCR0B = TCCR0B & 0b11111000 | mode;
      TCCR1B = TCCR1B & 0b11111000 | mode;
  } else if(pin == 3 || pin == 11) {
    switch(divisor) {
      case 32: mode = 0x03; break;
      case 64: mode = 0x04; break;
      case 128: mode = 0x05; break;
      case 256: mode = 0x06; break;
      case 1024: mode = 0x7; break;
      default: return;
    TCCR2B = TCCR2B & 0b11111000 | mode;
anyone?
i am still getting the error. I need help
What version of the IDE are you using? For what Arduino?
That is as useless as saying "I got it from the internet".
i was saying i did not write the code. I am using an arduino pro mini with a ftdi adapter from adafruit and i am using arduino 1.6.8
anyone?
i also hooked up my tft to the board and jumped the switch and plugged in the ac adapter and my screen only turned on and flashed a little bit and now my screen will not turn on? Is it the software because i partially programmed the arduino, but then i ran into the error. Did i solder something wrong on the pcb, or will the screen work normally after i find out to fix the programming error?
But you are STILL not saying WHERE you got it.
If you have fried the LCD, I'd guess yes.
Doesn't seem likely. Doesn't seem likely that you'll ever provide enough information to correct the programming error, either.
The tft display works. I just have to hold down the reset button. I got the iron.h and stationLOGO.h files from https://github.com/CSchlipp/SolderingStation/tree/master/arduino. Those are the updated files but i am not using the main SolderStation.ino from the fork because it does not work with the screen i have. I got the main SolderStation.ino file from here: https://github.com/ConnyCola/SolderingStation/tree/master/arduino I think that the screen did not work when i don't have th ereset button held because the arduino is partially programmed, not fully. I keep getting that error while programming.
anyone?
i need help programming this thing. I need to finish my soldering station. Will anyone help me please?
Still having issue to compile SolderStation? I just change Color565 to tft.Color565, it does compile ok. Now I bought incorrect display for it, instead of QDTech, I bougth the Adafruit version.. need to find the differences..
