Can't program basic circuits!
Hi
So, I just got a basic Arduino Uno board with some example circuits in the guide. Just to get used to programming, I have built a basic blinking LED connected to pin 13.
However, whenever I try to upload code, it will not work.
error: expected constructor, destructor, or type conversion before '(' token
is the error message. This comes up even when uploading simple code like
pinMode(13,OUTPUT);
I know if I can fix this I will quickly get to grips with programming, but just can't fix this error!
Please Help!!
Post your whole program otherwise we are just guessing at what the problem might be
How to use this forum
Post your code, there will be something wrong there.
My code:
pinMode(13, OUTPUT);
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
I know it's basic but its just to get me started.
You need to surround your code with {}.
Look at the examples!
Still wont work!!
sketch_mar07d:6: error: expected constructor, destructor, or type conversion before '(' token
Really confused?!?!?!
sketch_mar07d:6: error: expected declaration before '}' token
{void setup()
digitalWrite(13, HIGH);}
delay(1000);}
[code/]
Please edit your post, select the code, and put it between [code] ... [/code] tags.
You can do that by hitting the # button above the posting area.
This was explained here: How to use this forum
Look at the examples. Don't just leave stuff out or put braces wherever you feel like it.
