Hello guys! I'm new to all this XBee stuff, and after doing some research, I decided to try it out.
The problem is, I can't get the darn things to do anything. My setup is as follows:
2x Arduino UNO [ https://www.sparkfun.com/products/11021 ]
2x XBee Shield [ https://www.sparkfun.com/products/12847 ]
2x XBee Series 2 Module [ XBee 2mW PCB Antenna - Series 2 (ZigBee Mesh) - WRL-11217 - SparkFun Electronics ]
Also, I am following the guide seen here: http://arduino.cc/en/Guide/ArduinoWirelessShieldS2
My current task is getting the module talking to XCTU; however, everything I have tried had left me at the "Reset your device and try again" screen. I have tried the following things:
- Arduino has been
- Hardwired in reset
- Programmed with a empty loop
- Removed the ATMEGA chip from the board
- Shield has been placed in both serial positions
- XCTU
- Tried the new fancy looking version and the old version shown in the tutorial
- Looped through every available baud rate
- Tried to send commands (+++) to the chip through the terminal
I did upload a program from that tutorial that spit out Hs & Ls and saw them just fine through the terminal in XCTU, but I could never connect. Any ideas?
