Cant push the motor when PWM<50
Hi, all
I use a L298n motor driver to push the Pololu motor https://www.pololu.com/product/992
When the PWM under 50 , the motor barely rotate . Is this normal? If so, Is there any motor driver can push the motor with PWM under 50, even under 10?
Thanks.
That is nromal. You need some current to start a motor and keep it running. Try the map() function https://www.arduino.cc/en/Reference/Map
Cant use higher amp output motor driver ?
You mean map i.e. 0~100 to 50~250?
More like 0-255 to 50-255.
