Can't read 24lc256 eeprom
I’m using an Arduino Uno to read an external 24lc256 eeprom. This program always shows me zeros in every location no matter what i write to the eeprom.
#include <Wire.h>
const byte DEVADDR = 0x50;
  Wire.begin();
  Serial.flush();
  delay(3000);
  // Now dump 256 bytes
  Serial.println("eeprom_dump(DEVADDR, 0, 256)");
  eeprom_dump(DEVADDR, 0, 256);
void eeprom_dump(byte devaddr, unsigned addr, unsigned length)
  // Start with the beginning of 16-bit page that contains the first byte
  unsigned startaddr = addr & (~0x0f);
  // stopaddr is address of next page after the last byte
  unsigned stopaddr  = (addr + length + 0x0f) & (~0x0f);
  for (unsigned i = startaddr; i < stopaddr; i += 16) {
    byte buffer[16]; // Hold a page of EEPROM
    char outbuf[6];  //Room for three hex digits and ':' and ' ' and '\0'
    sprintf(outbuf, "%03x: ", i);
    Serial.print(outbuf);
    eeprom_read_buffer(devaddr, i, buffer, 16);
    for (int j = 0; j < 16; j++) {
      if (j == 8) {
        Serial.print(" ");
      sprintf(outbuf, "%02x ", buffer[j]);
    Serial.print(" |");
      if (isprint(buffer[j])) {
        Serial.print(buffer[j]);
      else {
        Serial.print('.');
    Serial.println("|");
int eeprom_read_buffer(byte deviceaddr, unsigned eeaddr,
byte * buffer, byte length)
  // Three lsb of Device address byte are bits 8-10 of eeaddress
  byte devaddr = deviceaddr | ((eeaddr >> 8) & 0x07);
  byte addr    = eeaddr;
  Wire.beginTransmission(devaddr);
  Wire.write(int(addr));
  Wire.endTransmission();
  Wire.requestFrom(devaddr, length);
  int i;
  for (i = 0; i < length && Wire.available(); i++) {
    buffer[i] = Wire.read();
  return i;
Do this first How to post code properly
Pete
