Hey Guys,
I have a very simple project: some DS18B20 sensors that should measure the temperature and my Arduino Uno sends the data to my computer. Everything works perfectly fine on Windows 7. And it also works when I use the Serial Monitor in the Arduino API on Linux (OpenSuse 13.2).
Here’s what it looks like in the Serial Monitor (Win and Linux) for 2 connected sensors:
ROM = 28EC98A5500DE 26.69 C
ROM = 281CFFA450063 27.31 C
No more Sensors
No more Sensors
The problem starts when I want my python script to store the values. Again, on Windows it works.
This is what some typical lines, send by the arduino, look like in my python script:
ROM = 281CFFA450063ROM = 28EC98A5500DE 26.44 C
50063 27.62 C
26.44 C
Most of the lines received are just weird. Missing characters or missing ‘\n’. That makes it very annoying …
Does anyone has an idea what could cause this problem?
Arduino Code (more or less just copied from the examples):
#include <OneWire.h>
// temperature sensors DS18B20 to serial port
// one data request of all sensors per second
OneWire ds(10); // on pin 10 (a 4.7K resistor is necessary)
void setup(void) {
void loop(void) {
byte i;
byte type_s;
byte data[12];
byte addr[8];
float celsius;
if ( !ds.search(addr)) {
Serial.println("No more Sensors");
ds.reset_search();
return;
Serial.print("ROM = ");
for( i = 0; i < 8; i++) {
Serial.print(addr[i], HEX);
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
ds.reset();
ds.select(addr);
ds.write(0xBE, 1); // Read Scratchpad, with parasite power on at the end
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
celsius = (float)raw / 16.0;
Serial.print(" ");
Serial.print(celsius);
Serial.println(" C");
And the interesting python3 part:
import serial
arduino = serial.Serial(port="/dev/ttyS0", baudrate=9600, timeout=5)
while True:
line = arduino.readline()
print(line)
if not ("No more Sensors" in line):
do_something()
else:
break
