can't read LOW ?
Here's the situation:
int trigger = 12;
(...etc)
if(digitalRead(trigger)==HIGH){
  digitalWrite(8, HIGH);
if(digitalRead(trigger) == LOW){
  digitalWrite(8, LOW);
I have pin_8 connected to voltage supplier with a wire. when I plug the wire, it normally goes to HIGH meaning that it read HIGH correctly
but when I unplug the wire, it keeps HIGH, why? I know that when an INPUT is not connected to circuit, it reports random changes in pin state but how can I put the pin state at LOW when it senses no current, and after it been previously set to HIGH?
Add a (10K) pulldown resistor to the pin: pin connected to resistor; other side of resistor connected to ground (GND).
softuino: but when I unplug the wire, it keeps HIGH, why?
An unconnected INPUT pin is said to be floating. I can't give the best explanation on just how that happens but you can't trust an unconnected pin for input unless you turn the internal pullup on, and then it will read HIGH.
To turn the internal pullup on, set the pin mode as INPUT and then digitalWrite the same pin HIGH. To turn that off, digitalWrite it LOW. The internal pullup supplies voltage through about 20k ohms when it's on.
That will pull the pin LOW through 20k ohms (pull-down resistor as Coding Badly described). However, using pull-up is recommended for digital inputs (reverse logic). You don't need to supply your own resistors; use the internal ones provided to you!
dkl65:
AVR processors do not have internal pulldown resistors. What I described was an [u]external[/u] pulldown resistor. Writing LOW to a pin configured as an INPUT turns off the internal pullup resistor.
The internal pullup enables a very safe switch sensing between a pin and ground though yes, the logic is "reversed".
It is called a floating input, read this:- http://www.thebox.myzen.co.uk/Tutorial/Inputs.html
Oops! So writing LOW to an input pin puts it into high impendance (completely unconnected, floating) mode. So you need to write HIGH to the input pin.
You need to have it hooked up like the examples on Mike's page there. Depending on how you hook it up you should use digitalWrite() to engage the internal pullup or not. If the pullup is used then grounding the pin through your switch will cause the pin to -read- LOW and when the switch is open it should read HIGH. The pullup is just a 20k resistor between power and the pin that you can switch on or off using digitalWrite().
How is your understanding of basic electricity? Do you know Ohm's Law?
