Hey there,
for measuring particulate matter in ambient air, I recently purchased an Plantower PMS5003 Air Quality Sensor and connected it with my Arduino MEGA2560. I wired the hardware according to Interfacing PMS5003 PM2.5 Air Quality Sensor with Arduino and uploaded the following code:
`/* Test sketch for Adafruit PM2.5 sensor with UART or I2C */
#include "Adafruit_PM25AQI.h"
// If your PM2.5 is UART only, for UNO and others (without hardware serial)
// we must use software serial...
// pin #2 is IN from sensor (TX pin on sensor), leave pin #3 disconnected
// comment these two lines if using hardware serial
#include <SoftwareSerial.h>
SoftwareSerial pmSerial(2, 3);
Adafruit_PM25AQI aqi = Adafruit_PM25AQI();
// Wait for serial monitor to open
while (!Serial) delay(10);
Serial.println("Adafruit PMSA003I Air Quality Sensor");
// Wait one second for sensor to boot up!
// If using serial, initialize it and set baudrate before starting!
// Uncomment one of the following
//Serial1.begin(9600);
pmSerial.begin(9600);
// There are 3 options for connectivity!
//if (! aqi.begin_I2C()) { // connect to the sensor over I2C
//if (! aqi.begin_UART(&Serial1)) { // connect to the sensor over hardware serial
if (! aqi.begin_UART(&pmSerial)) { // connect to the sensor over software serial
Serial.println("Could not find PM 2.5 sensor!");
while (1) delay(10);
Serial.println("PM25 found!");
PM25_AQI_Data data;
if (! aqi.read(&data)) {
Serial.println("Could not read from AQI");
delay(500); // try again in a bit!
return;
Serial.println("AQI reading success");
Serial.println(F("---------------------------------------"));
Serial.println(F("Concentration Units (standard)"));
Serial.print(F("PM 1.0: ")); Serial.print(data.pm10_standard);
Serial.print(F("\t\tPM 2.5: ")); Serial.print(data.pm25_standard);
Serial.print(F("\t\tPM 10: ")); Serial.println(data.pm100_standard);
Serial.println(F("Concentration Units (environmental)"));
Serial.print(F("PM 1.0: ")); Serial.print(data.pm10_env);
Serial.print(F("\t\tPM 2.5: ")); Serial.print(data.pm25_env);
Serial.print(F("\t\tPM 10: ")); Serial.println(data.pm100_env);
Serial.print(F("Particles > 0.3um / 0.1L air:")); Serial.println(data.particles_03um);
Serial.print(F("Particles > 0.5um / 0.1L air:")); Serial.println(data.particles_05um);
Serial.print(F("Particles > 1.0um / 0.1L air:")); Serial.println(data.particles_10um);
Serial.print(F("Particles > 2.5um / 0.1L air:")); Serial.println(data.particles_25um);
Serial.print(F("Particles > 5.0um / 0.1L air:")); Serial.println(data.particles_50um);
Serial.print(F("Particles > 10 um / 0.1L air:")); Serial.println(data.particles_100um);
I used the commands necessary for an UART connection. The serial monitor showed that the board finds the sensor but it cannot read the data from it. The monitor displays "Could not read from AQI". Therefore i just want to ask if i should use another connection method (I2C?) or if there is something wrong with my sensor/code?
Hope there is someone who can help me. Thanks in advance
