Can't read rotary encoder
Hi guys,
I have some problems when reading rotary encoder. I have a rotary encoder produced by autonic with e50s8 - 3600 - 3 - t - 24 as a serial number of it. I have read the manual book and the datasheet, it can be supplied directly with 5 v. Then I have been trying to read it more about 2 days but I got nothing.
This is my code:
#define encoder0PinA 3
#define encoder0PinB 2
volatile unsigned int encoder0Pos = 0;
boolean A_set;
boolean B_set;
  pinMode(encoder0PinA, INPUT);
  pinMode(encoder0PinB, INPUT);
// encoder pin on interrupt 0 (pin 2)
  attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
  attachInterrupt(1, doEncoderB, CHANGE);
  Serial.begin (9600);
void loop(){
//Check each second for change in position
    int A = digitalRead(encoder0PinA);
    int B = digitalRead(encoder0PinB);
    Serial.print(A);
    Serial.print(" ");
    Serial.print(B);
    Serial.print(" ");
    Serial.print("Index:"); Serial.println(encoder0Pos, DEC);
  delay(9);
// Interrupt on A changing state
void doEncoderA(){
  // Low to High transition?
  if (digitalRead(encoder0PinA) == HIGH) {
    A_set = true;
    if (!B_set) {
      encoder0Pos = encoder0Pos + 1;
  // High-to-low transition?
  if (digitalRead(encoder0PinA) == LOW) {
    A_set = false;
// Interrupt on B changing state
void doEncoderB(){
  // Low-to-high transition?
  if (digitalRead(encoder0PinB) == HIGH) {
    B_set = true;
    if (!A_set) {
      encoder0Pos = encoder0Pos - 1;
  if (digitalRead(encoder0PinB) == LOW) {
    B_set = false;
I got the code from the playground web of arduino, if I'm not mistake, I forget it.....
what I get is, when I rotate the rotary encoder the index value can't be increased and when I rotate to the other direction the index value can't be decreased too. I have trying to see what digital pin get and I use digitalwrite() syntax but the result is aslways zero (0).....
can any one help me please, I confuse with this thing.... :confused: :confused: :confused:
Help the forum help you. Post a schematic of your. actual. wiring. of the encoder to the Arduino.
That encoder requires 12-24 VDC for power. E50S8-3600-3-T-24
If you use a 12V power supply, the outputs should be 0 to 9V. So, use a 2:1 (1K and 1K) voltage divider on the A, B, Z outputs, and make sure that the divider output does not exceed 5V, or you will destroy the Arduino.
thanks u for u'r reply dough and jremington.....
ya sure here is my connection
output rotary encoder >>>> arduino
A (black) D2
B (white) D3
V0 (Blue) Gnd
V+ (brown) 5V
Z (orange) ------ not used ---
any way is there any mistake that I have done with my wiring??
oh ya jremington, thank u, but how can u know that the output is 9 volt, I have read the datasheet and I could not find it out...
Yes, wrong power supply and no voltage divider. The "24" in the model number is critical. STUDY THE DATA SHEET.
