Hi everyone. I'm writing a program to send data from DHT11 Sensor to a meshnetwork,. I'm using "painlessMesh" library. Here is my code
#include <painlessMesh.h>
#include "DHT.h"
#define DHTPIN 4 // what digital pin the DHT sensor is connected to
#define DHTTYPE DHT11 //there are multiple kinds of DHT sensors
DHT dht(DHTPIN, DHTTYPE);
// MESH Details
#define MESH_PREFIX "NGHI" //name for your MESH
#define MESH_PASSWORD "NGHI1234" //password for your MESH
#define MESH_PORT 5555 //default port
//Number for this node
int nodeNumber = 2;
//String to send to other nodes with sensor readings
Scheduler userScheduler; // to control your personal task
painlessMesh mesh;
void sendMessage() ;
Task taskSendMessage( TASK_SECOND * 1 , TASK_FOREVER, &sendMessage );
void sendMessage()
// Serializing in JSON Format
DynamicJsonDocument doc(1024);
float h = dht.readHumidity();
float t = dht.readTemperature();
doc["TEMP"] = t;
doc["HUM"] = h;
String msg ;
serializeJson(doc, msg);
mesh.sendBroadcast( msg );
Serial.println("from node2");
Serial.println(msg);
taskSendMessage.setInterval((TASK_SECOND * 10));
// Needed for painless library
void receivedCallback( uint32_t from, String &msg ) {
String json;
json = msg.c_str();
DeserializationError error = deserializeJson(doc, json);
if (error)
Serial.print("deserializeJson() failed: ");
Serial.println(error.c_str());
void newConnectionCallback(uint32_t nodeId) {
Serial.printf("--> startHere: New Connection, nodeId = %u\n", nodeId);
void changedConnectionCallback() {
Serial.printf("Changed connections\n");
void nodeTimeAdjustedCallback(int32_t offset) {
Serial.printf("Adjusted time %u. Offset = %d\n", mesh.getNodeTime(), offset);
mesh.setDebugMsgTypes( ERROR | STARTUP ); // set before init() so that you can see startup messages
mesh.init( MESH_PREFIX, MESH_PASSWORD, &userScheduler, MESH_PORT );
mesh.onReceive(&receivedCallback);
mesh.onNewConnection(&newConnectionCallback);
mesh.onChangedConnections(&changedConnectionCallback);
mesh.onNodeTimeAdjusted(&nodeTimeAdjustedCallback);
userScheduler.addTask( taskSendMessage );
taskSendMessage.enable();
mesh.update();
But when i compile this program, it can' show the temperature and humidity data from DHT11
I tested my DHT11 with another simple program and there is no error with hardware of this sensor
What should i do to solve this problem ? Thank you verymuch
