I'm using a sensor WF100DPZ for pressure measurement with arduino UNO in SPI mode. Here's the code:
#include <SPI.h>
const int chipSelectPin = 10; // Choose the appropriate digital pin for chip select
SPI.begin();
pinMode(chipSelectPin, OUTPUT);
// Wake up the sensor
digitalWrite(chipSelectPin, LOW);
delay(10);
digitalWrite(chipSelectPin, HIGH);
// Wait for the sensor to stabilize
// Set SDO mode (4-wire SPI, LSB first)
setSDOMode(0);
// Read and print the Part ID
byte partID = readPartID();
Serial.print("Part ID: 0x");
Serial.println(partID, HEX);
// Read the Data registers
int dataMSB = readRegister(0x06);
int dataCSB = readRegister(0x07);
int dataLSB = readRegister(0x08);
// Read the Temperature registers
int tempMSB = readRegister(0x09);
int tempLSB = readRegister(0x0A);
// Combine the MSB, CSB, and LSB values
long rawData = ((long)dataMSB << 16) | ((long)dataCSB << 8) | dataLSB;
int rawTemperature = (tempMSB << 8) | tempLSB;
// Start pressure measurement
startPressureMeasurement();
if (readRegister(0x02) & 0x01) {
// Read the final converted value from SCO
int measurementValue = readMeasurementValue();
Serial.print("Final Converted Value from SCO: ");
Serial.println(measurementValue);
Serial.println("Error: Data not ready.");
// Wait for a moment before reading again
void setSDOMode(byte sdoMode) {
// Select the sensor
// Send the command to set SDO mode
SPI.transfer(0x00); // SPI_Ctrl register address
SPI.transfer(sdoMode << 7); // Set the SDO mode
// Deselect the sensor
byte readPartID() {
// Send the command to read Part ID
SPI.transfer(0x01); // Part_ID register address
// Read the Part ID
byte partID = SPI.transfer(0);
return partID;
int readRegister(byte regAddr) {
// Send the command to read from the specified register
SPI.transfer(regAddr);
// Read the register value
int regValue = SPI.transfer(0);
return regValue;
void startPressureMeasurement() {
// Send the command to start pressure measurement (CMD register address)
SPI.transfer(0x30); // CMD register address
SPI.transfer(0x18); // Set sleep_time to 0001 (62.5ms) and measurement_control to 00b (single shot pressure measurement)
SPI.transfer(0x01); // Set SCO to 1 to start conversion
int readMeasurementValue() {
// Send the command to read measurement value
SPI.transfer(0x06); // DATA_MSB register address
// Read the measurement value
int measurementValue = (SPI.transfer(0) << 16) | (SPI.transfer(0) << 8) | SPI.transfer(0);
return measurementValue;
here's the circuit:
and here's the datasheet:
WF100D 规格书.pdf (1.4 MB)
the serial monitor shows:
where am I wrong?
