AWS CODE (The value of output= 0)
#include "secrets.h"
#include <WiFiClientSecure.h>
#include <MQTTClient.h>
#include <ArduinoJson.h>
#include "WiFi.h"
#include "LiquidCrystal_I2C.h"
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define Vp 25
#define ACS712_PIN 26
// The MQTT topics that this device should publish/subscribe
#define AWS_IOT_PUBLISH_TOPIC "esp32/pub"
#define AWS_IOT_SUBSCRIBE_TOPIC "esp32/sub"
int initialValue;
int avg;
int acc;
int x;
int ctr;
float weight2[5];
float current;
float weight;
float power;
WiFiClientSecure net = WiFiClientSecure();
MQTTClient client = MQTTClient(256);
void connectAWS()
WiFi.mode(WIFI_STA);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.println("Connecting to Wi-Fi");
while (WiFi.status() != WL_CONNECTED)
Serial.print(".");
// Configure WiFiClientSecure to use the AWS IoT device credentials
net.setCACert(AWS_CERT_CA);
net.setCertificate(AWS_CERT_CRT);
net.setPrivateKey(AWS_CERT_PRIVATE);
// Connect to the MQTT broker on the AWS endpoint we defined earlier
client.begin(AWS_IOT_ENDPOINT, 8883, net);
// Create a message handler
client.onMessage(messageHandler);
Serial.print("Connecting to AWS IOT");
while (!client.connect(THINGNAME)) {
Serial.print(".");
delay(100);
if(!client.connected()){
Serial.println("AWS IoT Timeout!");
return;
// Subscribe to a topic
client.subscribe(AWS_IOT_SUBSCRIBE_TOPIC);
Serial.println("AWS IoT Connected!");
void publishMessage()
StaticJsonDocument<200> doc;
doc["Weight (Kg)"] = weight;
doc["Power consumption (W)"] = power;
char jsonBuffer[512];
serializeJson(doc, jsonBuffer); // print to client
client.publish(AWS_IOT_PUBLISH_TOPIC, jsonBuffer);
void messageHandler(String &topic, String &payload) {
Serial.println("incoming: " + topic + " - " + payload);
deserializeJson(doc, payload);
const char* message = doc["message"];
pinMode(Vp, INPUT);
pinMode(ACS712_PIN, INPUT);
lcd.init();
lcd.backlight();
acc = 0;
for (int i = 0; i < 5; i = i + 1) {
delay(80); //80
acc = acc + analogRead(Vp);
delay(50); //50
initialValue = acc / 5;
delay(5000);
Serial.println(initialValue);
ctr = 0;
connectAWS();
acc = 0;
avg = analogRead(Vp);
delay(80);
delay(50);
avg = acc / 5;
weight = (avg - initialValue) / 17.5;
if (weight < 0)
weight = 0;
// Read the current from the ACS712 sensor
current = analogRead(ACS712_PIN) * 0.0048828125;
// Calculate the power
power = current * weight;
Serial.print("Weight: ");
Serial.print(weight);
Serial.println("Kg");
Serial.print("Current: ");
Serial.print(current);
Serial.println("A");
Serial.print("Power Consumption: ");
Serial.print(power);
Serial.println("W");
lcd.setCursor(0, 1);
lcd.print("Power(W)=");
lcd.print(power);
lcd.setCursor(0, 0);
lcd.print("Load(kg)=");
lcd.print(weight);
publishMessage();
client.loop();
WITHOUT AWS (The value shown)
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16,2);
#define Vp 25
int initialValue;
int avg;
int acc;
int x;
int ctr;
float weight2[5];
float current;
float power;
float voltage=12;
pinMode(Vp, INPUT);
lcd.init();
lcd.backlight();
acc = 0;
delay(80); //80
delay(50); //50
initialValue = acc/5;
delay(5000);
ctr = 0;
acc = 0;
//delay(80);
delay(50);
avg = acc / 5;
float weight = (avg - initialValue) / 17.5;
if (weight < 0)
weight = 0;
// Print the current and power to the serial monitor
//Serial.print("IV: ");
//Serial.print(initialValue);
// Serial.println("Avg: ");
//Serial.print(avg);
// Print the current and power to the LCD
lcd.print(power);
lcd.print(weight);
