can't read variables outside of while loop
int s1 = 4;
int s2 = 5;
int s3 = 6;
int s4 = 7;
unsigned long time1;
unsigned long time2;
unsigned long time3;
unsigned long time4;
int S1 = 0;
int S2 = 0;
int S3 = 0;
int S4 = 0;
pinMode(s1,INPUT);
pinMode(s2,INPUT);
pinMode(s3,INPUT);
pinMode(s4,INPUT);
while(1)
while(S1==LOW)
{ S1 = digitalRead(s1);
if (S1==HIGH)
time1=micros();
Serial.println(time1);
while(S2==LOW)
{ S2 = digitalRead(s2);
if (S2==HIGH)
time2=micros();
Serial.println(time2);
while(S3==LOW)
{ S3 = digitalRead(s3);
if (S3==HIGH)
time3=micros();
Serial.println(time3);
while(S4==LOW)
{ S4 = digitalRead(s4);
if (S4==HIGH)
time4=micros();
Serial.println(time4);
if (S1==HIGH&&S2==HIGH&&S3==HIGH&&S4==HIGH)
{break;
Serial.println('+++++++++++++++++');
void loop(){
can't read the code...
I think that you must come up with a better description of the problem.
You are aware that your while loops don't loop? You enter the loop and next unconditionally break from it.
while(S1==LOW)
  if (S1==HIGH)
     time1=micros();
See the problem now?
Please remember to use code tags when posting code
sterretje:
No, all the loops work properly, except that when I break out of the while(1) I can't
serial print variables any more time1, time2, time3, time4
Serial.println('+++++++++++++++++');Oops
I can't
What does that mean?
AWOL:
Serial.println('+++++++++++++++++');OopsWhat does that mean?
I commented it out as well as Serial.print(time1), it seems to be working now.
Thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I was supposed to use " instead of '
Thanks you again.
Delta_G:
If those while loops "work" as written then they really need to be if statements. You have a break that isn't contained by any if or anything else so it's only going over once. That's what if statements do.
Thank you for the tip, will try it
no, it doesn't work with if only instead of while
What is "it" that doesn't work?
Post the complete new code.
gfvalvo:
Will do - I think I found the mistake, missing curly brackets
Regards
This works perfectly:
int s1 = 4;
int s2 = 5;
int s3 = 6;
int s4 = 7;
int S1 = 0;
int S2 = 0;
int S3 = 0;
int S4 = 0;
pinMode(s1,INPUT);
pinMode(s2,INPUT);
pinMode(s3,INPUT);
pinMode(s4,INPUT);
while(1)
if (S1==HIGH)
{ time1=micros();
// Serial.println(time1);
if (S2==HIGH)
{ time2=micros();
// Serial.println(time2);
if (S3==HIGH)
{ time3=micros();
// Serial.println(time3);
if (S4==HIGH)
{ time4=micros();
// Serial.println(time4);
{break;
Serial.println("+++++++++++++++++");
Serial.println("time1");
Serial.println("time2");
Serial.println("time3");
Serial.println("time4");
void loop(){
Except this version only catches micros when button pressed consecutively, and I need random
(previous version did it)
Think it's about time you started posting your code with Code Tags as requested in Reply #3.
Need to figure out yet how to do it
telecom55:
...which is why there's a handy explanation at the top of this forum section.
