Can't receive 433 Mhz signal
Dear all,
I have a problem with my Arduino Uno receiving the signal of a remote (433.92 Mhz) for radio control sockets.
I can receive the signal of the remote of the first set I bought with the code below. However, with my second set I do not receive any signal at all, even though the remote interacts correcly with the corresponding sockets.
I dismounted the remote and the used transmitter datasheet can be found here:
http://pdf1.alldatasheet.com/datasheet-pdf/view/591640/LUGUANG/HDR433M.html
Does anyone have an idea why I don’t receive the signal?
Thanks a lot!
Best,
Alex
#include <RCSwitch.h>
int dataPin=0; //Pin2
RCSwitch mySwitch = RCSwitch();
  mySwitch.enableReceive(dataPin);  // Pin 2!
    if (mySwitch.available()) {
    int value = mySwitch.getReceivedValue();
    if (value == 0) {
      Serial.print("Unbekannter Code");
      //Serial.print("Empfangen ");
      Serial.println( mySwitch.getReceivedValue() );
      //Serial.print(" ");
      //Serial.print( mySwitch.getReceivedBitlength() );
      //Serial.print("bit ");
      //Serial.print(" Protokoll: ");
      //Serial.println( mySwitch.getReceivedProtocol() );
    mySwitch.resetAvailable();
The socket may use a data encoding protocol that is not compatible with the RCSwitch library.
Follow these instructions to verify transmissions and investigate the problem from the ground up.
