boylesg
December 29, 2017, 5:18am
1
I have a HC-05 connected to an arduino mega via Serial2.
And I have a MIT App Inventor app running on my android phone.
I have an issue where I can successfully send serial data from my andoid phone to the arduino mega.
But I can't receive serial data on my android phone from the arduino.
The connections between the arduino and the HC-05 are definitely correct upon checking with my multimeter.
I have a voltage divider between arduino Tx and HC-05 Rx, consisting of a 10k resistor and a 18k resistor.
But I notice that most people seem to use voltage dividers in the range 1k to 3k.
And I have noticed that the HC-05 LED does not flash when the arduino is transmitting serial data to the HC-05. I assume the LED should be flashing?
Is the voltage divider I have used likely to the cause of the failure to receive data from the arduino/HC-05?
boylesg
December 29, 2017, 6:05am
2
Tried binding to the Arduino/HC-05 from my Windows PC and sending/receiving serial data.
Same problem - can send data to the Arduino OK but I can't receive it from the Arduino
boylesg:
Your higher values may be to high for the input impedance or capacitance of the bluetooth device.
Try the lower values.
Tom...
boylesg
December 29, 2017, 11:02am
4
Never mind I found what I did wrong.
I soldered in a 100k resistor instead of a 10k resistor in my voltage divider.
I used the blue metal film resistors and I find their color coding less intuitive.
boylesg:
Yes, they can be misleading, I have come to the habit of measuring ALL my resistors like that before putting them in circuit.
The blue body colour bleeds through and band colour applied to it.
Tom..
