can't reset yun to factory
Hi guys,
After I did some changes to the network setting on Yun board, I found the ‘consolepixel’ example doesn’t work anymore. So I try to reset the board to factory following http://playground.arduino.cc/Hardware/Yun#restoring_a_yun. However, it doesn’t reboot after “reset-to-factory-anyway”, like this
root@(none):/# cd /usr/bin
root@(none):/usr/bin# ./reset-to-factory-anyway
But it didn’t reset:( Can anyone give me some clues on how to reset it? I’m using windows 7 and the reboot log is in the attachment.
Cheers,
Jiaqi
yun-reboot-log.txt (11.6 KB)
Hi guys,
I found one very interesting thing. When I tried to program Yun through USB, the 'consolepixel' sketch didn't work. But I just tried to program it through router (choose IP address in port) and it just works!
Cheers,
Jiaqi
Sounds like USB issues. Does the Serial Monitor work? Do you have the right port selected? Does it show up in the list of ports? Maybe try a different cable? Maybe try a different USB port? (Keep in mind that if you plug it into a different USB port on your computer, it will often show up with a different serial port name.)
while(!Console);
to Make console ready
 ssh root@ yourYunsName.local 'telnet localhost 6571'
 then pressing enter. When prompted for the password, enter it.
This example is designed to work with TCP/IP only.
