I am aware that this subject was already discussed, but I've never found a solution depsite the read posts.
when trying to upload a sketch onto an Arduino Due I get the known error about the serial port:
No device found on ttyACM0
Failed uploading: uploading error: exit status 1
Then I try to run the IDE with sudo, getting the alert that I should use the --no-sandbox option:
marco@Viognier:~/programs/arduino\> sudo ./arduino-ide
[sudo] password for marco:
[0703/095044.803887:FATAL:electron_main_delegate.cc(294)] Running as root without --no-sandbox is not supported. See https://crbug.com/638180.
Trace/breakpoint trap
Then I add the option and a series of errors is thrown:
sudo ./arduino-ide --no-sandbox
Arduino IDE 2.1.0
Starting backend process. PID: 9635
[9620:0703/095104.999912:ERROR:bus.cc(392)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[9620:0703/095104.999963:ERROR:bus.cc(392)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
Authorization required, but no authorization protocol specified
[9620:0703/095105.033750:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.037288:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.040146:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.043031:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.045680:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.048186:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.051531:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.054433:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.057123:ERROR:gpu_process_host.cc(957)] GPU process exited unexpectedly: exit_code=1024
[9620:0703/095105.057141:FATAL:gpu_data_manager_impl_private.cc(417)] GPU process isn't usable. Goodbye.
I have tried, as suggested in previous posts, to fix port access to my username with no success:
sudo usermod -a -G dialout <username>
Does anybody know how to fix this issue permanently ?
Many thanks in advance,
Marco
