I'm getting about 190 kSps with the ADC1022S021 on SPI using the RobTillaart ADC08XS library but using this SPI1 code only get zeros. I tried every suggestion I found on line and other SPI1 wirings. Got good results on other wirings with SPI. Just Pico RP2040 on Philhower core with Win11 Arduino. Does ADC08XS talk to SPI1 ?
// Credits to
// AUTHOR: Rob Tillaart
// URL: https://github.com/RobTillaart/ADC08XS
#include "ADC08XS.h"
#include <spi.h>
ADC122S adc;
#define bufSize 256
uint16_t buf[bufSize] = {0};
void setup(){
delay(3000);
SPI1.setRX(12); // MISO orange 16 4
SPI1.setTX(11); // MOSI red 19 3
SPI1.setSCK(14); // yellow 18 2
SPI1.setCS(13); // white 17 5
SPI1.begin();
adc.begin(13); //
for (int i = 0; i<bufSize; i++){
buf[i] = adc.read(0);
Serial.print(i);
Serial.print(" ");
Serial.println(buf[i]);
delay(10);
void loop(){
b707
March 1, 2024, 3:55pm
2
Look at the library code...
If you use custom SPI other than default, you must pass the reference to your SPI instance to ADC constructor:
larry_gorham:
ADC122S adc(&SPI1);
It would be helpful to know which Arduino board you're using.
Fixed!!!
ADC122S adc(&SPI1); Worked
Wow that was fast.
Thank You
This corrected code now works fine on core 1 with the SPI running faster. It samples at 174 kSps. Which is a bit slower than running on core 0 (190 kSps) but acceptable for now. I'll try the faster single channel ADC chip next. Many thanks to all.
// Credits to
#include <spi.h>
ADC122S adc(&SPI1);
#define bufSize 256
uint32_t SPIspeed = 24000000UL;
void setup(){
void loop(){
void setup1(){
delay(3000);
adc.setSPIspeed(SPIspeed);
SPI1.begin();
adc.begin(13); //
Serial.print(i);
Serial.print(" ");
delay(10);
void loop1(){
system
Closed
August 28, 2024, 6:20pm
9
