Can't save anything from w5500 web to arduino mega eeprom
#include <SPI.h>
#include <Ethernet.h>
#include <EEPROM.h>
#include "Mudbus.h"
#define LED_PIN    5
#define NUM_LEDS   8
#define RL1 14
#define RL2 15
#define EEPROM_IP_ADDRESS 0
#define EEPROM_GATEWAY 4
#define EEPROM_SUBNET 8
#define EEPROM_CONFIG_SET 12
#define EEPROM_MAC_ADDRESS 13
IPAddress ip, gateway, subnet;
uint8_t mac[6];
EthernetServer server(80);
Mudbus Mb;
Adafruit_NeoPixel strip(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
const uint8_t numInputs = 10;
const uint8_t inputPins[numInputs] = {6, 7, 8, 9, 4, 3, 19, 18, 17, 16};
uint8_t tugas[numInputs] = {1, 1, 1, 1, 1, 1, 2, 4, 5, 9};
uint8_t antrian[numInputs] = {0};
uint8_t perintah = 0;
unsigned long previousMillis = 0;
  randomSeed(analogRead(0));  // Initialize random number generator
  loadIPSettings();
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  Serial.print(F("Server is at "));
  Serial.println(Ethernet.localIP());
  pinMode(RL1, OUTPUT);
  pinMode(RL2, OUTPUT);
  strip.begin();
  strip.show();
  for (uint8_t i = 0; i < numInputs; i++) {
    pinMode(inputPins[i], INPUT_PULLUP);
  Mb.Run();
  for (uint8_t i = 0; i < 10; i++) {
    Mb.R[i] = tugas[i];
  ledStartupSequence();
  Mb.Run();
  handleEthernetClient();
  digitalWrite(RL1, Mb.C[10]);
  digitalWrite(RL2, Mb.C[11]);
    Mb.C[i] = digitalRead(inputPins[i]);
    tugas[i] = Mb.R[i];
  updateAntrian();
  perintah = getMaxTugas();
  handleLEDControl(perintah, currentMillis);
void loadIPSettings() {
  if (EEPROM.read(EEPROM_CONFIG_SET) == 1) {
    for (uint8_t i = 0; i < 4; i++) {
      ip[i] = EEPROM.read(EEPROM_IP_ADDRESS + i);
      gateway[i] = EEPROM.read(EEPROM_GATEWAY + i);
      subnet[i] = EEPROM.read(EEPROM_SUBNET + i);
    for (uint8_t i = 0; i < 6; i++) {
      mac[i] = EEPROM.read(EEPROM_MAC_ADDRESS + i);
    Serial.println(F("Loaded IP and MAC settings from EEPROM"));
    ip = IPAddress(192, 168, 1, 177);
    gateway = IPAddress(192, 168, 1, 1);
    subnet = IPAddress(255, 255, 255, 0);
    generateRandomMAC();
    Serial.println(F("Using default IP settings and generated MAC"));
  Serial.print(F("IP: ")); Serial.println(ip);
  Serial.print(F("Gateway: ")); Serial.println(gateway);
  Serial.print(F("Subnet: ")); Serial.println(subnet);
  Serial.print(F("MAC: "));
    Serial.print(mac[i], HEX);
    if (i < 5) Serial.print(':');
void saveIPSettings(IPAddress newIP, IPAddress newGateway, IPAddress newSubnet) {
    EEPROM.write(EEPROM_IP_ADDRESS + i, newIP[i]);
    EEPROM.write(EEPROM_GATEWAY + i, newGateway[i]);
    EEPROM.write(EEPROM_SUBNET + i, newSubnet[i]);
  EEPROM.write(EEPROM_CONFIG_SET, 1);
  Serial.println(F("IP settings saved to EEPROM"));
void saveMACSettings() {
    EEPROM.write(EEPROM_MAC_ADDRESS + i, mac[i]);
  Serial.println(F("MAC address saved to EEPROM"));
void generateRandomMAC() {
  mac[0] = 0xDE;  // Locally administered address
  for (int i = 1; i < 6; i++) {
    mac[i] = random(0xFF);
void handleEthernetClient() {
  if (client) {
    boolean currentLineIsBlank = true;
    String httpRequest = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        httpRequest += c;
        if (c == '\n' && currentLineIsBlank) {
          if (httpRequest.indexOf("POST /setip") != -1) {
            handleIPConfiguration(client, httpRequest);
          } else if (httpRequest.indexOf("POST /setmac") != -1) {
            handleMACConfiguration(client, httpRequest);
          } else if (httpRequest.indexOf("POST /generatemac") != -1) {
            handleGenerateMAC(client);
            sendWebPage(client);
        if (c == '\n') {
        } else if (c != '\r') {
          currentLineIsBlank = false;
    delay(1);
    client.stop();
void handleIPConfiguration(EthernetClient& client, const String& httpRequest) {
  IPAddress newIP, newGateway, newSubnet;
  if (parseIPSettings(httpRequest, newIP, newGateway, newSubnet)) {
    saveIPSettings(newIP, newGateway, newSubnet);
    sendResponse(client, F("IP settings updated. Please restart the device manually."));
    softReset();
    sendResponse(client, F("Invalid IP settings"));
void handleMACConfiguration(EthernetClient& client, const String& httpRequest) {
  String macStr = extractValueFromRequest(httpRequest, "mac");
  if (parseMACAddress(macStr)) {
    saveMACSettings();
    sendResponse(client, F("MAC address updated. Please restart the device manually."));
    softReset();
    sendResponse(client, F("Invalid MAC address"));
void handleGenerateMAC(EthernetClient& client) {
  saveMACSettings();
  sendResponse(client, F("New MAC address generated and saved. Please restart the device manually."));
  softReset();
bool parseIPSettings(const String& request, IPAddress& ip, IPAddress& gateway, IPAddress& subnet) {
  String ipStr = extractValueFromRequest(request, "ip");
  String gatewayStr = extractValueFromRequest(request, "gateway");
  String subnetStr = extractValueFromRequest(request, "subnet");
  return ip.fromString(ipStr) && gateway.fromString(gatewayStr) && subnet.fromString(subnetStr);
bool parseMACAddress(const String& macStr) {
  uint8_t temp[6];
  int values[6];
  int i;
  if (6 == sscanf(macStr.c_str(), "%x:%x:%x:%x:%x:%x", &values[0], &values[1], &values[2], &values[3], &values[4], &values[5])) {
    for (i = 0; i < 6; ++i) {
      temp[i] = (uint8_t) values[i];
    memcpy(mac, temp, 6);
    return true;
  return false;
String extractValueFromRequest(const String& request, const char* key) {
  int start = request.indexOf(key);
  if (start == -1) return "";
  start = request.indexOf('=', start) + 1;
  int end = request.indexOf('&', start);
  if (end == -1) end = request.indexOf(' ', start);
  if (end == -1) return "";
  return request.substring(start, end);
void sendWebPage(EthernetClient& client) {
  client.println(F("HTTP/1.1 200 OK"));
  client.println(F("Content-Type: text/html"));
  client.println();
  client.println(F("<html><head><title>Arduino Network Config</title></head><body>"));
  client.println(F("<h1>Arduino Network Configuration</h1>"));
  // IP settings form
  client.println(F("<h2>IP Settings</h2>"));
  client.println(F("<form method='post' action='/setip'>"));
  client.print(F("IP Address: <input type='text' name='ip' value='"));
  client.print(Ethernet.localIP());
  client.println(F("'><br>"));
  client.print(F("Gateway: <input type='text' name='gateway' value='"));
  client.print(Ethernet.gatewayIP());
  client.print(F("Subnet: <input type='text' name='subnet' value='"));
  client.print(Ethernet.subnetMask());
  client.println(F("<input type='submit' value='Update IP Settings'>"));
  client.println(F("</form>"));
  // MAC address form
  client.println(F("<h2>MAC Address</h2>"));
  client.println(F("<form method='post' action='/setmac'>"));
  client.print(F("MAC Address: <input type='text' name='mac' value='"));
    client.print(mac[i], HEX);
    if (i < 5) client.print(':');
  client.println(F("<input type='submit' value='Update MAC Address'>"));
  // Generate random MAC button
  client.println(F("<form method='post' action='/generatemac'>"));
  client.println(F("<input type='submit' value='Generate Random MAC'>"));
  client.println(F("</body></html>"));
void sendResponse(EthernetClient& client, const __FlashStringHelper* message) {
  client.println(F("Content-Type: text/plain"));
  client.println();
  client.println(message);
void softReset() {
  asm volatile ("  jmp 0");
void updateAntrian() {
    antrian[i] = digitalRead(inputPins[i]) == LOW ? tugas[i] : 0;
uint8_t getMaxTugas() {
  uint8_t maxTugas = 0;
    if (antrian[i] > maxTugas) {
      maxTugas = antrian[i];
  return maxTugas;
void handleLEDControl(uint8_t perintah, unsigned long currentMillis) {
  switch (perintah) {
    case 0: ledsOff(); break;
    case 1: blinkColor(strip.Color(0, 255, 0), 1000, currentMillis); break;
    case 2: blinkColor(strip.Color(255, 0, 0), 700, currentMillis); break;
    case 3: alternateBlink(strip.Color(0, 255, 0), 50, currentMillis); break;
    case 4: blinkColor(strip.Color(255, 255, 0), 1000, currentMillis); break;
    case 5: blinkColor(strip.Color(128, 0, 128), 700, currentMillis); break;
    case 6: blinkColor(strip.Color(255, 255, 255), 500, currentMillis); break;
    case 7: blinkColor(strip.Color(255, 20, 147), 300, currentMillis); break;
    case 8: blinkColor(strip.Color(255, 0, 0), 300, currentMillis); break;
    case 9: blinkColor(strip.Color(0, 0, 255), 200, currentMillis); break;
void ledsOff() {
  strip.clear();
  strip.show();
void blinkColor(uint32_t color, int interval, unsigned long currentMillis) {
  static bool ledState = false;
  if (currentMillis - previousMillis >= interval) {
    ledState = !ledState;
    strip.fill(ledState ? color : 0, 0, NUM_LEDS);
    strip.show();
void alternateBlink(uint32_t color, int interval, unsigned long currentMillis) {
  static uint8_t ledIndex = 0;
    strip.clear();
    strip.setPixelColor(ledIndex, color);
    strip.show();
    ledIndex = (ledIndex + 1) % NUM_LEDS;
void ledStartupSequence() {
  uint32_t colors[] = {strip.Color(255, 0, 0), strip.Color(255, 255, 0), strip.Color(0, 255, 0)};
  for (uint8_t i = 0; i < 3; i++) {
    strip.fill(colors[i], 0, NUM_LEDS);
    strip.show();
    strip.clear();
    strip.show();
    delay(900);
describe what happens in your sketch.
What serial Output do you get on Startup?
What serial Output do you get on Parameter Change?
Code displays failed to save, always displays "Invalid IP settings"
There is no single line which would output "Invalid IP settings" to the serial.
  loadIPSettings();
I can save this using the available serial, only the web can't be used yet
