cant see any serial data
hi,
im running a sketch but cant see any serial data, i get the following errors any ideas what im doing wrong? thank you
java.io.IOException: Bad file descriptor in nativeavailable at gnu.io.RXTXPort.nativeavailable(Native Method) at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532) at processing.app.Serial.serialEvent(Serial.java:258) at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732) at gnu.io.RXTXPort.eventLoop(Native Method) at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575) Error inside Serial.serialEvent() java.io.IOException: Bad file descriptor in nativeavailable at gnu.io.RXTXPort.nativeavailable(Native Method) at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532) at processing.app.Serial.serialEvent(Serial.java:258) at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732) at gnu.io.RXTXPort.eventLoop(Native Method) at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
now sorted, got a naughty usb port
