Can't see data in arduino iot cloud
Hi everybody,
I am writing because I can't see the data of ESP8266 in the dashboard neither arduino cloud dashboard nor arduino iot cloud app.
I am new with arduino and the cloud.
I have read many post but I am not able to find the thing that is working wrong.
Thanks
#include "DHT22.h"
#include "ESP8266WiFi.h"
#include "thingProperties.h"
DHT22 dht22(D4);
  // Initialize serial and wait for port to open:
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  //Mostrar mensaje de éxito, dirección IP y dirección MAC asignada
  Serial.print("Conectando a:\t");
  Serial.print(WiFi.SSID());
  Serial.print("IP address:\t");
  WiFi.printDiag(Serial);
  Serial.printf("MAC Address = %s/n",WiFi.softAPmacAddress().c_str());
  ArduinoCloud.update();
  // Your code here
  float hr = dht22.getHumidity();
  float temp = dht22.getTemperature();
  int soilhum = analogRead(0);
  delay (1000);
  // imprimir la humedad y temperatura medida al monitor serial
  Serial.print(F("Hum: "));
  Serial.print(hr);
  Serial.print(F(" % "));
  Serial.print(F("Temp: "));
  Serial.print(temp);
  Serial.println(" *C");
  Serial.print("Hum. Suelo: ");
  Serial.println(soilhum);
// Code generated by Arduino IoT Cloud, DO NOT EDIT.
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char DEVICE_LOGIN_NAME[]  = "cef9d447-6868-4c37-8077-XXXXXXXXXX";
const char SSID[]               = SECRET_SSID;    // Network SSID (name)
const char PASS[]               = SECRET_OPTIONAL_PASS;    // Network password (use for WPA, or use as key for WEP)
const char DEVICE_KEY[]  = SECRET_DEVICE_KEY;    // Secret device password
float hr;
float temp;
int soilhum;
void initProperties(){
  ArduinoCloud.setBoardId(DEVICE_LOGIN_NAME);
  ArduinoCloud.setSecretDeviceKey(DEVICE_KEY);
  ArduinoCloud.addProperty(hr, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(temp, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(soilhum, READ, ON_CHANGE, NULL);
Hi, you have re-defined variables in the loop, so you are not updating variables defined into thingProperties.h file. You need to directly use variables already defined into your loop() implementation.
Regards
Thank you Macolomb,
It worked.
