Hi! I'm using 3 Xbees. 2 are configured as router AT and the other one as coordinator AT. The codes on the routers are for reading temperatures from a LM and from 3 OneWire DS18B20 sensors :
#include <SoftwareSerial.h>
float temp;
int tempPin = 0;
SoftwareSerial xbee(4, 3);
xbee.begin(9600);
temp = analogRead(tempPin);
temp = temp * 0.48828125;
//Serial.print("TEMPRATURE = ");
//Serial.print(temp);
// Serial.print("*C");
//Serial.println();
//delay(1000);
xbee.print("Temp D: "); xbee.print(temp);
and
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into pin 3 on the Arduino
#define ONE_WIRE_BUS 8
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
DeviceAddress camera1Temp = { 0x28, 0xF6, 0x7C, 0xA0, 0x05, 0x00, 0x00, 0x0E };
DeviceAddress camera2Temp = { 0x28, 0x2A, 0x61, 0xDD, 0x03, 0x00, 0x00, 0xC3 };
DeviceAddress camera3Temp = { 0x28, 0x52, 0x8D, 0x30, 0x05, 0x00, 0x00, 0x04 };
SoftwareSerial xbee(4, 3); // RX, TX
void setup(void)
// start serial port
// Start up the library
sensors.begin();
// set the resolution to 10 bit (good enough?)
sensors.setResolution(camera1Temp, 10);
sensors.setResolution(camera2Temp, 10);
sensors.setResolution(camera3Temp, 10);
xbee.begin(9600);
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
Serial.print("Eroare citire temperaturi");
Serial.print("C: ");
Serial.print(tempC);
Serial.print(" F: ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
delay(2000);
//Serial.print("Citire temperaturi...\n\r");
sensors.requestTemperatures();
/*delay(1000);
Serial.print("Temperatura in camera 1: ");
printTemperature(camera1Temp);
Serial.print("\n\r");
Serial.print("Temperatura in camera 2: ");
printTemperature(camera2Temp);
Serial.print("Temperatura in camera 3: ");
printTemperature(camera3Temp);
float temp1 = sensors.getTempC(camera1Temp);
float temp2 = sensors.getTempC(camera2Temp);
float temp3 = sensors.getTempC(camera3Temp);
/*Serial.print(int(temp1*100));
Serial.println(int(temp2*100));
Serial.println(int(temp3*100));
//Serial.print("\n\r\n\r");
xbee.print("Temp A: "); xbee.print(temp1);
delay(100);
xbee.print("Temp B: "); xbee.print(temp2);
delay(100);
xbee.print("Temp C: "); xbee.print(temp3);
delay(100);
When connecting the XBee coordinator in X-CTU i can see the receiving text and temperatures. But I can't see anything when connecting the XBee coordinator to an Arduino. I connected the XBee to the arduino on pins 0 and 1 not 3 and 4 as with the routers.(I tried with them too)
if (Serial.available()>0)
Serial.write(Serial.read());
After this I want to procces the incoming text from the 4 sensors....but I can't see anything on the arduino. Can anyone figure out what is wrong?
