Hi all,ime a noob and need some help compiling all of this code ive attached,ime not sure wich ide version it was ment for or if its all differant versions,ive tryed most ide and get errors,can someone alter the code so it compiles under just one ide or show me how to compile it all or wich ide each one will work under,its code for the blinkM mk2 led blinky leds. ive added a zip of the sketches i want to compile for attiny 85 or 44 as thats what the mcu its for i think so even if you could compile a hex for me for the both attinys.thanks in advance fr any help.
What errors do you get when compiling with 1.6.5r5 of the IDE? (that is the latest "good" version)?
Have you installed the libraries correctly? Extract them to the libraries folder (google will give you more details if this is something you're unclear on).
Have you installed a core to add support for the ATTiny chips? (Try mine - board manager URL is in my sig )
Also, goddamned BlinkM, don't even remind me. I dropped like $60+ on a bunch of them from the kickstarter. Do you think I ever used one? Expensive boondoggle. I was never able to make it work reliably with IFTTT, so the notifications were worse than useless (a notification that works 95% of the time is worse than none at all, because it gives you a false sense of security when it's wrong) - but that was a couple years back.
If you want me to make the sketches build (testing not included) and give you the hex files, I'm happy to do that for a nominal fee (pm me) - my advice is free, but doing work for you isn't.
