This is my send code:
* 11/20/2019 This works.
* Receives data from Tx and prints it to 16x2 LCD.
#include <SoftwareSerial.h>
#include "ringbuffer.h"
* 6 -----TX
* 5 -----RX
* 2 -----AUX PULL Input
* 3 -----EN output
* 4 -----MO output
typedef enum
MODEL_INIT,
MODEL_RX,
MODEL_TX,
MODE_WAIT,
}MODEL_STATE;
MODEL_STATE state = MODEL_INIT;
引脚定义
#define GPIO_TX 6
#define GPIO_RX 5
#define GPIO_AUX 2
#define GPIO_EN 3
#define GPIO_MO 4
#define GPIO_RST 7
#define RB_MAX_LEN 512
#define MODEL_MAX_BUFFER_SIZE 200
#define SET_NORMAL_MODE() digitalWrite(GPIO_EN, LOW);digitalWrite(GPIO_MO, LOW);Serial.print("Normal mode\r\n")
#define SET_WAKE_MODE() digitalWrite(GPIO_EN, LOW);digitalWrite(GPIO_MO, HIGH);Serial.print("Wake mode\r\n")
#define SET_HALF_SLEEP_MODE() digitalWrite(GPIO_EN, HIGH);digitalWrite(GPIO_MO, LOW);Serial.print("Half Sleep mode\r\n")
#define SET_DEEP_SLEEP_MODE() digitalWrite(GPIO_EN, HIGH);digitalWrite(GPIO_MO, HIGH);Serial.print("Deep Sleep mode\r\n")
uint8_t rx_data[255];
rb_t pRb; ///< Ring buffer structure variable
uint8_t rbBuf[RB_MAX_LEN]; ///< Ring buffer data cache buffer
SoftwareSerial mySerial(GPIO_RX, GPIO_TX); // Define pin GPIO2 as RX and pin GPIO3 as TX.
// constants won't change. They're used here to set pin numbers:
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
#include <Wire.h>
#include <LCD.h>
#include <LiquidCrystal_I2C.h >
LiquidCrystal_I2C lcd(0x27,2,1,0,4,5,6,7);
int open8 = 8; // door open, pin 8 ***********************
int closed9 = 9; // door closed, pin 9 *******************
lcd.begin (20, 4);
lcd.setBacklightPin(3, POSITIVE);
lcd.setBacklight(HIGH);
pRb.rbCapacity = RB_MAX_LEN;
pRb.rbBuff = rbBuf;
rbCreate(&pRb);
mySerial.begin(9600); //Set Baud rate with DRF1268DS/DRF1262DS
while(mySerial.read()>= 0){} //clear serial buffer
Serial.begin(9600); //Set Baud rate with PC
Serial.println("sketch_jan25a_2020_lora_LCD_Tx_Garage");
delay(1500);
while(Serial.read()>= 0){} //clear serial buffer
noInterrupts(); //Disable interrupt
pinMode(GPIO_AUX, INPUT_PULLUP); //Set GPIO pin as input to connect AUX pin
pinMode(GPIO_RST, OUTPUT);
pinMode(GPIO_EN, OUTPUT); //Set GPIO as output to connect EN pin
pinMode(GPIO_MO, OUTPUT); //Set GPIO as output to connect MO pin
SET_NORMAL_MODE(); // Set power mode
interrupts(); //enable interrupt
digitalWrite(GPIO_RST, LOW); // Reset module DRF1268DS/DRF1262DS
delay(10);
digitalWrite(GPIO_RST, HIGH);
delay(10);
// Serial.print("systerm init ok...\r\n");
pinMode(open8, INPUT); // door open switch. Both inputs tied to grd through*************
pinMode(closed9, INPUT); // door closed switch. 10K resistors. *************************
int t;
if ((digitalRead(open8) == HIGH) && (digitalRead(closed9) == LOW)) // door open all the way. Red LED.
{ t = 111;
// Serial.println("111");
//Serial.println("DOOR OPEN");
if ((digitalRead(open8) == LOW) && (digitalRead(closed9) == HIGH)) // door closed all the way. Green LED.
{ t = 222;
//Serial.println("222");
// Serial.println("DOOR CLOSED");
if ((digitalRead(open8) == LOW) && (digitalRead(closed9) == LOW)) // door between closed and open. Blue LED.
{ t = 333;
//Serial.println("333");
//Serial.println("DOOR IN BETWEEN");
else if ((digitalRead(open8) == HIGH) && (digitalRead(closed9) == HIGH)) // ERROR
{ t =999 ;
//Serial.println("999");
// Serial.println("DOOR ERROR");
// const int a = ("BLUE 8_8 Tx ");
mySerial.println(t); // sends to module to be transmitted
delay(2000);
if(Serial.available()>0) //Read data from PC COM port
uint8_t len = Serial.readBytes(rx_data,MODEL_MAX_BUFFER_SIZE);
rbWrite(&pRb,rx_data, len); //Write data into the buffer of the Arduino board
if(mySerial.available()>0) //Read data from module DRF1268DS/DRF1262DS
uint8_t len = mySerial.readBytes(rx_data,MODEL_MAX_BUFFER_SIZE);
Serial.write(rx_data,len); //Output data to the COM port of PC
lcd.setCursor(2,0);
lcd.write(rx_data,len);
lcd.setCursor(14,0);
lcd.write(" ");
lcd.setCursor(15,0);
lcd.write(" ");
lcd.setCursor(3,1);
lcd.write("GARAGE");
// lcd.setCursor(0, 2);
// lcd.write(" ");
delay(3000);
lcd.clear();
switch(state)
case MODEL_INIT:
if(digitalRead(GPIO_AUX) == HIGH)
// Serial.print("module init is ok\r\n");
state = MODEL_RX;
case MODEL_RX:
if(digitalRead(GPIO_AUX) == HIGH) //Check if the module DRF1268DS/DRF1262DS is in idle status or not
uint16_t len = rbCanRead(&pRb); //Get the data length in the buffer of Arduino board
if(len > 0)
if(len > MODEL_MAX_BUFFER_SIZE)
rbRead(&pRb,rx_data,MODEL_MAX_BUFFER_SIZE); //Check if the data length in the buffer exceeds 200 bytes
mySerial.write(rx_data,MODEL_MAX_BUFFER_SIZE);
}else
rbRead(&pRb,rx_data,len); //Read out the data in the buffer and transfer it to the module DRF1268DS/DRF1262DS
mySerial.write(rx_data,len);
state = MODEL_TX;
case MODEL_TX:
state = MODEL_RX;
default: break;
