can't send 8266 variable to PHP file
Hello !
i’ve read numerous threads on this topic, but, unfortunately, i can’t get the data from the 8266 to reach the PHP file on the server.
I’m using the ESP8266-01, it connects to the network well (WiFiManager).
The code is supposed to send a string variable (data) to a PHP file: datacollector.php on the subdomain : “8266.morgulis.net”. (the PHP file creates an HTML file - this works, only this…)
I’ve tried changing the permissions of the public_html folder (to be 777-RWX) and the permissions of the PHP file, but i guess that wasn’t the problem.
here is the code, any help will be highly appreciated!
The Sketch:
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <WiFiManager.h>
WiFiClient client;
const char server_name[] = "www.domain.com";
    WiFiManager wifiManager;
    wifiManager.autoConnect("AutoConnectAP");
    Serial.println("connected...)");
    int V1 = 1234;
    int V2 = 5678;
    String data = "V1=" + (String) V1 + "&V2=" + (String) V2 ;
        Serial.println("\nStarting connection to server...");
        if (client.connect(server_name, 80))
            Serial.println("connected to server");
        } //if client.connet
           int V1 = 1234;
           int V2 = 5678;
              //WiFi.printDiag(Serial);
              client.println("POST /datacollector.php HTTP/1.0");
              client.println("Host: www.domain.com");
              client.println("User-Agent:ESP8266/1.0");
              client.println("Connection: close");
               client.println("Content-Type: application/x-www-form-urlencoded");
              client.print("Content-Length: ");
              client.println(data.length());
              client.println(data);
              client.stop();
               Serial.println("\n");
               Serial.println("My data string: ");
               Serial.println(data);
               Serial.println("It's size:: ");
               Serial.println(data.length());
               delay(2000);
          }// if conneted to server
} //loop
The PHP code:
<?php
$TimeStamp = "The current time is " . date("h:i:sa");
file_put_contents('dataDisplayer.html', $TimeStamp, FILE_APPEND);
   if( $_REQUEST["V1"] ||  $_REQUEST["V2"] )
   echo " Value1 is: ". $_REQUEST['V1']. "
   echo " Value2 is: ". $_REQUEST['V2']. "
$var1 = $_REQUEST['V1'];
$var2 = $_REQUEST['V2'];
$WriteMyRequest= "<p> Value1 is : "     . $var1 . "  </p>".
 "<p> And Value2 is : " . $var2 . "  </p>
file_put_contents('dataDisplayer.html', $WriteMyRequest, FILE_APPEND);
Thank you!
noiasca:
I don't see where you send your
data
to the client.
You do a client.stop after the html header, without sending the body. So you never send your data.
Thanks, I added the line with the data back, that's how I had it in the first place, it doesn't send it either.
noiasca:
... than you do still something wrong, but nobody can help you as you don't post your updated code.
Don't forget that you need the empty line between header and body.
I updated the code in the original message.
Regarding the empty line, it should come before the line that sends the data?
Like that?
client.println();
client.stop();
noiasca:
yes, looks ok. Does it work now? When not - what response do you get from your server?
IT DOES!!!
Thank you!
