Can't slow down SPI clock speed
I am trying to slow the SPI clock speed way down. It seems like nothing I try changes the clock speed on my scope. This should result in a much slower than measured speed of 10 MHz.
SPI.beginTransaction(SPISettings(125000, MSBFIRST, SPI_MODE0));
SPI.setClockDivider(128);
Is SPI speed locked on these devices because of the WIFI communications?
I think you're using this incorrectly. As described here, try
SPI.setClockDivider(SPI_CLOCK_DIV128);
Note that from here, we have
#define SPI_CLOCK_DIV128 0x03
Thanks for the response. I was using this #define earlier. I guess with all of my trying of different things I left the wrong value in there. I will go back to this and test again.
Using:
My measured SPI clock pulse width is about 100 ns. I am assuming a higher clock divider should result in slower clock. I have also tried different max speed settings from 10MHz down to 125 KHz. Again, nothing seems to change the SPI clock speed.
