Can't starting bridge
Hey,
I have a Arduino YUN. If I upload "File>exemple>bridge>WiFIStatus" and start the "Serial Monitor", I only can read "Starting bridge..." and the Sketch stopped or wait. The L13 LED doesn't shine.
I change the Sketch:
  Serial.print("Starting bridge...");
    Bridge.begin();  // make contact with the linux processor
  Serial.println("Done\n");
but the Sketch stopped on "Bridge.begin();".
I tested the YUN with other cable on other computer, I made a full reset.
Do you have an idea? Maybe the bridge is defekt?
best regards dony
Reset to factory settings
Start with other bridge sample of IDE.
I tested some more example but it dosn't work. I reseted the board complet. The board is new. Sketches works normal with other hardware but not with the bridge!
I think this is a bad board. lg dony
Request RMA.
dony: I tested some more example but it dosn't work. I reseted the board complet. The board is new. Sketches works normal with other hardware but not with the bridge!
@dony, Check you IDE make sure you have the correct board selected. Check Menu: Tools->Board->Arduino Yun
Also make sure you have the latest IDE.
Jesse
I have the lastest IDE (1.6.5), I testet it also with an older release. (1.5.7) I checked the IDE Settings, and YUN is selected. I also tested with the USB Port and the IP Port. I tested all on an other Computer with Windows 10, and with Windows 7.
@sonnyyu: Today I go to the shop where I bought the board.
Thanks for help! lg Dony
Today I went to the shop where I bought the YUN. I get a new board. The bridge of the new board works without any problems!
Thank's for help! Lg Dony
Glad to hear. Thanks for the update.
