I'm trying to create a robot that follows a line but only after you press the button, and when both sensors read stop then stop the while loop. The first problem, while loop doesn't stop at all, and the second is if it starts with a certain "if" that "if" doesn't change even if the sensor is reading something else.
#define in1 5 //Motor1 L293 Pin in1
#define in2 6 //Motor1 L293 Pin in1
#define in3 3 //Motor2 L293 Pin in1
#define in4 7 //Motor2 L293 Pin in1
#define stopLED 2
#define R_S 11//ir sensor Right
#define L_S 10 //ir sensor Left
int stop = 1;
void setup(){
pinMode(R_S, INPUT);
pinMode(L_S, INPUT);
pinMode(stopLED, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
void loop(){
if((digitalRead(13) == HIGH)){
delay(100);
Serial.println("1");
stop = 0;
while(stop==0){
if((digitalRead(R_S) == 0)&&(digitalRead(L_S) == 0)){
digitalWrite(stopLED, LOW);
digitalWrite(in1, HIGH); //Right Motor forword Pin
digitalWrite(in2, LOW); //Right Motor backword Pin
digitalWrite(in3, LOW); //Left Motor backword Pin
digitalWrite(in4, HIGH); //Left Motor forword Pin
Serial.println("f");
stop=0;
function
if((digitalRead(R_S) == 1)&&(digitalRead(L_S) == 0)){
digitalWrite(in1, LOW); //Right Motor forword Pin
digitalWrite(in2, HIGH); //Right Motor backword Pin
stop=0;
Serial.println("l");
if((digitalRead(R_S) == 0)&&(digitalRead(L_S) == 1)){
digitalWrite(in3, HIGH); //Left Motor backword Pin
digitalWrite(in4, LOW); //Left Motor forword Pin
stop=0;
Serial.println("r");
if((digitalRead(R_S) == 1)&&(digitalRead(L_S) == 1)){
digitalWrite(stopLED, HIGH);
stop=1;
Serial.println("STOP");
