I am trying to make the code below work, but i'm at a loss trying to toggle pin 4.
Pin 2 is connected to an rc receiver channel, when the rc signal goes from approx 988 to approximately 1014 pin 4 should toggle.
the stanby value for the rc signal is approx 988.
when i get this working i will add 17 more switch functions and use the arduino as a 18 channel multiswitch
if more info is needed please let me know.
thanks in advance.
#define MSpin 2
#define SW1 4
volatile long StartTimeMS = 0;
volatile long CurrentTimeMS = 0;
volatile long PulsesMS = 0;
int PulseWidthMS = 0;
unsigned long previousMillis = 0; // delay variable
const long interval = 50; // delay time in ms
int PSTBY = 1000;
int P1L = 1009;
int P1H = 1019;
int SW1State = 0; // current state of the button
pinMode(MSpin, INPUT_PULLUP);
pinMode(SW1, OUTPUT);
digitalWrite(SW1, LOW);
digitalWrite(SW1, HIGH);
attachInterrupt(digitalPinToInterrupt(MSpin), PulseTimerMS, CHANGE);
void PulseTimerMS() {
CurrentTimeMS = micros();
if (CurrentTimeMS > StartTimeMS) {
PulsesMS = CurrentTimeMS - StartTimeMS;
StartTimeMS = CurrentTimeMS;
//only save pulse lengths that are less than 2000 microseconds
if (PulsesMS < 2000) {
PulseWidthMS = PulsesMS;
Serial.println(PulseWidthMS);
noInterrupts();
unsigned long currentMillis = millis(); // delay variable
if (currentMillis - previousMillis >= interval) { // check if the current time minus the previous time is less or equal to the value on line 12
previousMillis = currentMillis; // if previous line is true, wait for amount of ms set on line 12
if (PulsesMS < PSTBY)
if ((PulsesMS > P1L) && (PulsesMS < P1H)) {
if (SW1State == LOW)
SW1State = HIGH;
} else if (SW1State == HIGH)
SW1State = HIGH;
interrupts();
First, bump up your baud rate to 115200. That will reduce any effect of the time it takes to print. Maybe not a problem yet, but just for the future.
Next, the ISR goes on CHANGE, so how do you know you are measuring the time the pulse HIGH, not LOW?
It's early and I can't run your code, just reading through the tiny window while in transit. So maybe you are getting reliable pulse widths. How do the printed values look?
This is odd code oddly formatted
SW1State = HIGH;
SW1State = HIGH;
and is equivalent to this
SW1State = HIGH;
SW1State = HIGH;
I think, again the tiny window but it looks like you have some stray semicolons in there and maybe are missing a pair of { braces } or two, review the syntax of the if/else statement and be certain the code is doing what you want.
I look better when i am in the lab, I am sure those lines are going for something but falling short.
i tried some things with no luck based on your reply, i get good values in the serial monitor.
when i change my code to the below, it works but the but the connected led only is on when when i hold the button.
#define MSpin 2
#define SW1 4
int PSTBY = 1000;
int P1L = 1006;
int P1H = 1019;
//noInterrupts();
//if (currentMillis - previousMillis >= interval) { // check if the current time minus the previous time is less or equal to the value on line 12
//previousMillis = currentMillis; // if previous line is true, wait for amount of ms set on line 12
//if (PulsesMS < PSTBY)
else digitalWrite(SW1, HIGH);
//interrupts();
i changed the code, it toggles.
Now i have figure out how to implement a debounce
this the current code;
#define MSpin 2
#define SW1 4
int PSTBY = 1000;
int P1L = 1006;
int P1H = 1019;
noInterrupts();
digitalWrite(4, !digitalRead(4));
interrupts();
I'm curious why you have this in the first place. Whenever I have read in RC pulses, I just acted on what was received based on some threshold.
In other words, why pass PulseWidthMS = PulsesMS; at all if later on you're acting on PulsesMS; but debugging with this:
Other thought and I admit wrapping my head around using millis() (or micros()) sometimes makes my brain hurt even though it is a simple enough concept, but my question to you is this:
It's timing the length of pulses. Or it's timing the gap between pulses. It doesn't know which of those 2 things it is timing, could be either. @alto777 already pointed this out.
Chances are it is measuring the lengths of pulses. But there's a ~10% chance it is measuring the gap between them. The interrupt routine doesn't actually check the signal to see if it's HIGH or LOW.
const int sw1 = 4; // left switch(?) 1 on pin 4
const int rx1 = 5; // edit changed from 4 to say, 5 to reflect a channel in
unsigned long val;
pinMode(rx1, INPUT);
pinMode(sw1, OUTPUT);
digitalWrite(sw1, LOW); // let's start LOW
val = pulseIn(rx1, 20000);
if (val <= 999) {
else if (val >= 1000) {
Serial.println(val); //print to the serial port
(Although the else-if condition is unnecessary: if the pulse length isn't <= 999 it must be >= 1000.)
One possible "problem" with pulseIn() is that it is blocking code. It could waste up to 2ms of processing time every 20ms. In this case, I don't see it as a problem at all. I can't see that there's anything that the Arduino could be usefully doing during that "wasted" time.
I expect some excitement no matter the approach when @rolf102 goes forward with
At that point, it may make more sense to hunt down a library that can receive and decide the PPM, SBUS or IBUS signal that the receiver can output.
I don't use pulseIn(). I don't know if it would be hard to use it for decoding PPM, and it certainly would not be usable for SBUS or IBUS.
The multiple channels of PWM a receiver might offer could be fed to multiple inputs and each handled by pulseIn(), tests would have to be made to see how the blocking nature of the call affected such processing.
Of course it depends on what else is going on. Slow responses may not matter if it is not a car or helicopter being controlled.
Then the blocking nature of pulseIn() could potentially become a problem. Some pulses would inevitably be missed. Maybe 2 out of 3 would be missed. It's not clear if that would be a serious problem in this project or not.
But if interrupts were used, then no problem... except that most arduino don't have 18 external interrupt pins. Pin-change interrupts could be used I guess but they are a little more complex to implement.
I don't know as much about advanced RC data protocols, but it sounds like @alto777 does, so that could be a much more sensible approach than sampling 18 different PWM signals.
It's working all 18 switches, thanks a lot!! @alto777.
Ill use it in a model tug boat, the perceived response is adequate.
I might try implementing SBUS and/or IBUS in the future when my programming ability has improved beyond where it is now.
I chose this method over using pulsein() for the very reason that it has a similar effect on the program as the basic delay() function.
i used THIS blog post as reference.
It looks like you are only grabbing the control pulse from one channel, and the 18 actions are all ranges within what that channel can produce.
I am curious about what you are manipulating at the transmitter to control 18 toggles.
Can you reliably toggle #7 and #13, for example, without inadvertently toggling any of 8 through including 12?
I don't argue with success, but once you get a bit further along, use this sketch, which works, as the basis for version 2, which will benefit hugely from your knowledge of arrays, functions and loops and a few others of the next things you'll be learning.
I have a Nano Every. For many things they work perfectly well and no special fuss is required. As luck has it I am up to a few things that are different enough that the Every is waiting instead for the perfect project to build it into and forget about.
