Atconnect to WPA SSID: Wlan
Attempting to connect to WPA SSID: Wlan
Connected to wifi
SSID: Cancel
IP Address: 192.168.1.61
signal strength (RSSI):-57 dBm
Starting connection to server...
disconnecting from server.
So, I've read a lot about that problem and some people meant I need to update the firmware. I followed this tutorial: How to update the official Arduino Wifi Shield but I get some error messages in Mac Terminal I don't understand:
Airchen:apple apple$ sudo sh ArduinoWifiShield_upgrade_mac.sh -a /Applications/Arduino.app/Contents/Resources/Java/ -f shield
Arduino WiFi Shield upgrade
Disclaimer: to access to the USB devices correctly, the dfu-programmer needs to be used as root. Run this script as root.
./avr-objcopy: '/Applications/Arduino.app/Contents/Resources/Java//hardware/arduino/firmwares/wifi-shield/wifi_dnld.elf': No such file
./avr-objcopy: '/Applications/Arduino.app/Contents/Resources/Java//hardware/arduino/firmwares/wifi-shield/wifiHD.elf': No such file
****Upgrade WiFi Shield firmware****
ArduinoWifiShield_upgrade_mac.sh: line 33: dfu-programmer: command not found
ArduinoWifiShield_upgrade_mac.sh: line 34: dfu-programmer: command not found
ArduinoWifiShield_upgrade_mac.sh: line 35: dfu-programmer: command not found
Done. Remove the J3 jumper and press the RESET button on the shield.
Thank you!
What am I doing wrong? Thanks so much for your help.
I've read a lot and I'm now 1 step further. I can run the script to upgrade the firmware, but I still get this error in terminal:
Ok, i got it. I needed to install the dfu-programmer. That worked fine and I could update the WiFiShield Firmware.
But I get still the following error message:
AtD: Wlan
Connected to wifi
SSID: Cancel
signal strength (RSSI):-68 dBm
I haven't changed anything besides the wlan name und the password. My code:
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
This example connects to an unencrypted Wifi network.
Then it prints the MAC address of the Wifi shield,
the IP address obtained, and other network details.
Circuit:
* WiFi shield attached
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
#include <WiFi.h>
char ssid[] = "Wlan"; // your network SSID (name)
char pass[] = "removedPasswort"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
char server[] = "www.google.com"; // name address for Google (using DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(3000);
Serial.println("Connected to wifi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected to server");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
// check the network connection once every 10 seconds:
// if there are incoming bytes available
// from the server, read them and print them:
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting from server.");
client.stop();
// do nothing forevermore:
while(true);
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
void printWifiData() {
Serial.println(ip);
Serial.println(ip);
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
Serial.print(mac[5],HEX);
Serial.print(":");
Serial.print(mac[4],HEX);
Serial.print(":");
Serial.print(mac[3],HEX);
Serial.print(":");
Serial.print(mac[2],HEX);
Serial.print(":");
Serial.print(mac[1],HEX);
Serial.print(":");
Serial.println(mac[0],HEX);
void printCurrentNet() {
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
Serial.print(bssid[5],HEX);
Serial.print(":");
Serial.print(bssid[4],HEX);
Serial.print(":");
Serial.print(bssid[3],HEX);
Serial.print(":");
Serial.print(bssid[2],HEX);
Serial.print(":");
Serial.print(bssid[1],HEX);
Serial.print(":");
Serial.println(bssid[0],HEX);
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type:");
Serial.println(encryption,HEX);
First I've upgraded the firmware like written above. Then, I've downloaded IDE Version 1.0.2 from http://arduino.cc/en/Main/OldSoftwareReleases and installed it (on my Mac). Then it worked.
