Can't upload any code while using Rx and Tx connected
So, for a few days now I'm not able to program my ESP8266, It was working fine and I don't know what heppened. the error I'm getting:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5 Using Programmer : arduino Overriding Baud Rate : 115200 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail :
Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino Description : Arduino Hardware Version: 3 Firmware Version: 4.4 Vtarget : 0.3 V Varef : 0.3 V Oscillator : 28.800 kHz SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p) avrdude: reading input file "C:\Users\rdalb\AppData\Local\Temp\arduino_build_195363/Blink.ino.hex" avrdude: writing flash (928 bytes):
Writing | ######avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_paged_write(): (a) protocol error, expect=0x14, resp=0x64
avrdude: stk500_cmd(): programmer is out of sync
avrdude: stk500_cmd(): programmer is out of sync avrdude: stk500_cmd(): programmer is out of sync avrdude: stk500_cmd(): programmer is out of sync ... ... ...
... ... ... avrdude: stk500_cmd(): programmer is out of sync avrdude: stk500_cmd(): programmer is out of sync avrdude: stk500_cmd(): programmer is out of sync
| 100% 5.98s
avrdude: 928 bytes of flash written avrdude: verifying flash memory against C:\Users\rdalb\AppData\Local\Temp\arduino_build_195363/Blink.ino.hex: avrdude: load data flash data from input file C:\Users\rdalb\AppData\Local\Temp\arduino_build_195363/Blink.ino.hex: avrdude: input file C:\Users\rdalb\AppData\Local\Temp\arduino_build_195363/Blink.ino.hex contains 928 bytes avrdude: reading on-chip flash data:
Reading | avrdude: stk500_loadaddr(): (a) protocol error, expect=0x14, resp=0x48
avrdude: stk500_paged_load(): (a) protocol error, expect=0x14, resp=0x13
avr_read(): error reading address 0x0000 read operation not supported for memory "flash" avrdude: failed to read all of flash memory, rc=-2 avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x20
avrdude done. Thank you.
a few other things: I'm connecting Tx to Tx and Rx to Rx, COM port is verified. I've tried different ESP modules as well as different PC's, both windows 10 64bit.
Last thing, if i upload blink without tx and rx connected it uploads no problem, if i then connect the tx rx I am able to talk to the ESP module threw AT commands and Serial monitor without any issues.
I've searched around alot and wasn't able to find anything to solve, or even find out what the issue is.
Thank you in advance,
It is normal and expected that you need to disconnect external devices from pins 0 and 1 prior to uploading code.
Are you trying to compile for an ESP8266 or an UNO?
