HELP!
I am trying to upload a program onto my Arduino Uno (even happens when I upload a blank program). And I am getting this error:
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/private/var/folders/5c/brbfv9rd6yq4x6bmv9g4vyph0000gn/T/AppTranslocation/F9828822-D6DD-486D-803C-C99CB312C966/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/forestedwards/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbmodem14111
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
avrdude done. Thank you.
An error occurred while uploading the sketch
I have my board set to Arduino/Genuino Uno, and my serial port set to dev/cu.usbmodem14111 (Arduino/Genuino Uno)
I have uninstalled and reinstalled the Arduino IDE to multiple versions and still get the same error
I was able to upload programs perfectly fine the other day, and I have no idea why it isn't working now.
Help is very much appreciated, thanks!
