can't upload anything to my arduino
i had problem that i can't upload to my arduino even a simpler task my uploading progress isn't complete because this message
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files\Arduino\hardware/tools/avr/etc/avrdude.conf"
Using Port : \.\COM10 Using Programmer : arduino Overriding Baud Rate : 115200 avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Send: 0 [30] [20] avrdude: Recv: . [00] avrdude: stk500_getsync(): not in sync: resp=0x00
please help me
See if any of the issues mentioned in the attached document help you
Arduino troubleshooting for beginners.doc (368 KB)
Ballscrewbob: See if any of the issues mentioned in the attached document help you
it's can't upload not slow upload it always showed the message like above any another suggestion?
I just updated it so you may want to skip to the end sections…
BTW did you go through it ALL ?
kristiannova: i had problem that i can't upload to my arduino even a simpler task
Try uploading the sketch by AVR ISP. If still doesn't solve your issue, should re-burning the bootloader for AVR chip. Good luck.
