Hello,
I need to put another bootloader on my Arduino Pro Mini (3.3V / 8MhZ) to make OTA updates possible.
I followed this tutorial (Software / Flashen | AskSin++ only in German, sorry). Basically what I did is I compiled a sketch, then downloaded the bootloader from AskSinPP/bootloader/avr at master · pa-pa/AskSinPP · GitHub and created a *.hex file that contains both the bootloader and firmware.
I am using an Arduino UNO as ISP Programmer.
Uploading only the compiled sketch (without bootloader) works:
>>>: avrdude -c arduino -p m328p -P COM6 -b 115200 -v -v -e -U flash:w:"E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.eightanaloginputs.hex":a
avrdude.exe: Version 7.0
Copyright (c) Brian Dean, http://www.bdmicro.com/
Copyright (c) Joerg Wunsch
System wide configuration file is "E:/_dls/AVRDUDESS-2.14-portable/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
Serial program mode : yes
Parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Alias Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 1 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 1 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 1 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 4.4
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e950f (probably m328p)
avrdude.exe: erasing chip
avrdude.exe: reading input file "E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.eightanaloginputs.hex"
avrdude.exe: input file E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.eightanaloginputs.hex auto detected as Intel Hex
avrdude.exe: writing flash (19718 bytes):
Writing | ################################################## | 100% 3.17s
avrdude.exe: 19718 bytes of flash written
avrdude.exe: verifying flash memory against E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.eightanaloginputs.hex:
avrdude.exe: load data flash data from input file E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.eightanaloginputs.hex:
avrdude.exe: input file E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.eightanaloginputs.hex contains 19718 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 2.54s
avrdude.exe: verifying ...
avrdude.exe: 19718 bytes of flash verified
avrdude.exe done. Thank you.
But uploading the other *.hex file with bootloader included fails, I get a verification error:
>>>: avrdude -c arduino -p m328p -P COM6 -b 115200 -v -v -e -U flash:w:"E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.with_bootloader_JPLCSw5001.hex":a
Using Port : COM6
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 3
avrdude.exe: reading input file "E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.with_bootloader_JPLCSw5001.hex"
avrdude.exe: input file E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.with_bootloader_JPLCSw5001.hex auto detected as Intel Hex
avrdude.exe: writing flash (32768 bytes):
Writing | ################################################## | 100% 5.31s
avrdude.exe: 32768 bytes of flash written
avrdude.exe: verifying flash memory against E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.with_bootloader_JPLCSw5001.hex:
avrdude.exe: load data flash data from input file E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.with_bootloader_JPLCSw5001.hex:
avrdude.exe: input file E:\_dls\HM-LC-Sw2-FM-master\HM-LC-Sw2-FM-master\Software\HM-LC-Sw2-FM\HM-LC-Sw2-FM.ino.with_bootloader_JPLCSw5001.hex contains 32768 bytes
Reading | ################################################## | 100% 4.16s
avrdude.exe: verification error, first mismatch at byte 0x7e00
0x11 != 0x50
avrdude.exe: verification error; content mismatch
This are my settings:
Screenshot
I also tried changing fuse settings with avrdude, same problem:
PS E:\_dls\AVRDUDESS-2.14-portable> .\avrdude.exe -p m328p -c arduino -P COM6 -U lfuse:w:0xE2:m -U hfuse:w:0xD0:m
avrdude.exe: reading input file "0xE2"
avrdude.exe: writing lfuse (1 bytes):
Writing | | 0% 0.00s ***failed;
Writing | ################################################## | 100% 0.06s
avrdude.exe: 1 bytes of lfuse written
avrdude.exe: verifying lfuse memory against 0xE2:
avrdude.exe: verification error, first mismatch at byte 0x0000
0x00 != 0xe2
What is wrong, why can't I change fuse settings or upload another bootloader?
But uploading normal compiled sketched works, so the ISP Programmer (Arduino UNO) should work correctly. I also tried another Arduino Pro Mini, same problem.
