Hi, I've tried looking for solutions on this but hit a brick wall. I've tried on 3 different machines, 2 with Chrome on Windows 7 and 1 with Edge on Windows 10. I'm only trying to upload BLINK, so nothing difficult. When I use the desktop IDE there's no problem, so can't be hardware. I know I could stick with the desktop, but it is nice to be able to open the code on different machines so I can edit at home and work.
The full verbose output is attached, but a cut-down version is shown below.
Anyone else have this problem?
Thanks
Paul
Sketch uses 10552 bytes (4%) of program storage space. Maximum is 262144 bytes.
Programming with: Serial
Restarting in bootloader mode
Get port list before reset
[COM4]
Touching port COM4 at 1200bps
Set DTR off
Flashing with command:C:/Users/Paul/.arduino-create/arduino/avrdude/6.3.0-arduino9/bin/avrdude.exe -CC:/Users/Paul/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf -v -v -patmega2560 -cstk500v2 -PCOM4 -b57600 -Uflash:w:C:/Users/Paul/AppData/Local/Temp/arduino-create-agent345510061/Blink.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/Paul/.arduino-create/arduino/avrdude/6.3.0-arduino9/etc/avrdude.conf"
Using Port : COM4
Using Programmer : stk500v2
Overriding Baud Rate : 57600
avrdude: ser_recv(): programmer is not responding
avrdude: stk500v2_ReceiveMessage(): timeout
Verbose Output.txt (34.3 KB)
